This has been happening for a couple months on my Subaru, drives  great no issues and done quite a bit of servicing recently on the fluids and filters, but when driving sometimes I put my foot down nothing happens and even if I put it down almost all the way, but then it suddenly takes off. What does this sound like? I always fill up with 98, everyday at high speeds so I don't think it would be something like a clogged injector. Maybe a fuel pump failing?
7 hours ago, Rusty Nuts said:
What is the exact model of this mysterious Subaru.
Mysterious lol? 2001 impreza. Maybe throttle body needs a clean? The car is driven well I don't floor it or do any stupid shit. I wonder if it was that time I messed with the throttle position sensor, but I did put it back to normal.
10 hours ago, AlexAuba said:
it might also be an issue with the gearbox
It's an automatic, and it does shift smooth but every day after work it does shift a bit funny on this road I always drive on (just a normal straight road. I might be ovethinking it), when I changed the transmission fluid, the filter barely had any debree inside it like a couple of specs lol, it was also red the fluid so didn't look contaminated. My mechanic was surprised when he opened it, there was no discolouration.
Edited by silviaz
i have an sti these things are full of problems...clean or replace maf, clean crank angle sensor, make sure your plugs and wires are new. replace your 02. make sure you have a strong battery connection, ive seen bad connection cause all kinds of misfiring or  weird issues with these cars.  you should know by now to post a what year, make, model, etc to get better help. i personally cant stand the subaru forums bunch of kids and wierd mates on them so i figure crap out myself, but go through some pages on the butt buddy subaru forums sure you will find some info to get the old girl some help mate.
Ok, thanks for the feedback. 02 could use a replacement lol the light does pop up frequently lol, wires and spark plugs changed not too long ago, I'll see what I can do.
Before you replace the o2 sensor, replace your fuel filter, then check your fuel pump output and pressure. Check ALL vehicle ground wires. Cleaning all the ground connections won't hurt.
My fuel filter was replaced 10,000km ago i think.
i took it to my mechanic i need a new knock sensor, there was a code for a throttle position sensor but apprently its old. Suprisingly nothing for an exygen sensor. I wanted to ask do you think its a bad idea to buy a 20$ one from ebay as opposed to a 95$ from a retailer?
I don't recommend ebay LingLong brand anything, when the genuine stuff is outrageous price, I buy from Burson or Repco or any other place that will refund my money. Also if the part f**ks up you can jump up and down and shout at the human who sold it to you.
Repco is a rip off 200$ is oem apprently. I'll get one from a wrecker.
So how much was it from : any other place that will refund my money. Looking up one price on the internet is not shopping around for the best price bro.
13 minutes ago, silviaz said:
i saw 20$ ebay ones have a 5 year warranty.
Found one of these in a BMW once, it was so badly calibrated it didn't do the job, but not out of ecu range so didnt throw code.
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
