On 07/11/2020 at 8:35 PM, Robzilla32 said:
I accidentally brought home a tranny once. Nobody believed that story either
Ye na tryinga to say I didn't mean to buy a car with a shit tone of problems. Still luv it, but Im not gonna be rushing into buying a car again anytime soon.
See here's the thing. For the last 20 years R31s have been exclusively owned by people who only frequent Centrelink, the cheesecake shop and the bottle-o. Most of them can't even spell teeth, let alone say the word, let alone have more than 30% of their originals.
It hasn't led to R31s being very well looked after, for the most part.
  • Like 2
yeah na like apprently the 1st owner was a complete junga, like theirs so many random things the car came with (no crack pipes 😢) such as silhouette tail light garnishes and a f**king street poll for an exhaust tip, but the junkie kept a really nice interior which is wot kinda sold me
1 hour ago, mlr said:
Fark she is a vlean old girl
Nice score
Hahaha yeah man lean indeed, just gotta ignore the roof and rust spots in the body and boot, all that stuff is bound to empty my wallet sooner or later.
PS. (Don't have to answer this) but has anyone gotta trick to dealing with rust bubbles/rust in general, or are we all paying the cars weight in gold to get it fixed at the body shop
Wire wheel and converter, then throw on some paint and bondo, finish with a nice rattle can finish.
Don't worry about the exterior, just give it a cut and polish.
That patina look is in, just need some wide steel rims painted black to finish the look.
  • Thanks 1
3 minutes ago, trel said:
Yeah as mlr says rub back to bare metal, rustoleum, prime, then rattle can that bitch. Nice 31 otherwise dude, brings back memories.
yeah cheers guys I think I got a good idea how imma tackel it, but should i do the whole panel (when dealing with the rust spots) or just rattle can the parts that need it and hope it blends nicely.
yeah na was thinking about chasing down some rims with decent offset (still decided about colour), but for now i figure its cheaper to hunt down some ti hubcaps and roll with those for now
Depends how far you want to go with the car. Just do the spots if the rest of it looks ok, you'll know as you rub back how far you'll need to go anyway. Keep up the posts. Give her a nice detail and keep it clean, they're a really reliable car if it's in good order.
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
