So i brought this car a year ago with 250k on it with a blown ECU and a tight cam belt, Fixed that and is was a new car again. The problem has been that the compression cold is 140psi throughout the 6 and once hot they all drop evenly 20psi down to 120psi throughout the 6. its been like that for a year now and hasn't changed. it doesn't use oil really and doesn't fill up the catch can. the k&n filter on the catch can looks abit oily however. There's no noticeable blow by just a puff of white smoke out the catch can when you give it a hard rev.
I haven't done a leakdown test yet I've been putting it off. my question is what causes compression to drop like that? i have no information on the history besides it was owned my crackheads and it sat dormant for possibly more then 5 years. the motor looks super clean for how many km's it has and how trashed the suspension is. the car runs perfect but i can feel the 20psi loss as the car warms up.
i was thinking someone put a thicker head gasket on to drop the cr but that still doesn't answer the compression drop. its suppose to rise isn't it lol.
I've asked many mechanics and they cant explain it.
Hope someone can help!
Thanks.
https://www.sau.com.au/forums/topic/482142-r33-gts25t-compression-issue/
3 hours ago, blind_elk said:
Have you done a wet compression test?
Its a good idea, but it will confirm worn rings. The suspension didn't get rooted because the crackies drove it to church on Sundays. Or down to Supercheap for new filters, before the car wash.
Edited by Rusty Nuts
additional information
  • Like 1
hmm, its running 10psi atm, iv blown 2 turbos so far going any higher on the stock ones. Im still confused why the compression dropped 20psi just from warming up, and even more so why its 120psi hot and cold a year later. wouldnt it drop down to say 100psi once warmed up if its worn that much in the time iv owned it. if compression should be around 160-170+ and i have 120, shouldnt there be quite abit of blowby?
I forgot to take the crank case vent valve out of the manifold to get a true reading of how much blowby there is, i dc that. i took the catch can hose out and you can bearly notice air coming out, you have to squeeze the hose end and then its enough to feel like a gentle flow of air. 0 smoke. same if you give it a rev.
iv used the same comp tester for years to eliminate getting different readings.
Edited by JasonMate
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
    • Thanks @Duncan Ride height is fine. I think it's almost stock tbh. Happy to share a pic. I don't actually have a regular mechanic as haven't lived in Sydney too long. Could you or anyone recommend any shops in Sydney?
    • You just need a different blue slip shop (preferably one you regularly use as a mechanic), and make sure the coil overs are as close as possible to standard height
    • yeah the sugar refining companies were pushing for the same in Oz originally, all fuels were going to have 10% ethanol to make them "cheaper" (noting, that the loss in l/100 might be greater than the decrease in price). I guess they won that fight in Canadia
