So i brought this car a year ago with 250k on it with a blown ECU and a tight cam belt, Fixed that and is was a new car again. The problem has been that the compression cold is 140psi throughout the 6 and once hot they all drop evenly 20psi down to 120psi throughout the 6. its been like that for a year now and hasn't changed. it doesn't use oil really and doesn't fill up the catch can. the k&n filter on the catch can looks abit oily however. There's no noticeable blow by just a puff of white smoke out the catch can when you give it a hard rev.
I haven't done a leakdown test yet I've been putting it off. my question is what causes compression to drop like that? i have no information on the history besides it was owned my crackheads and it sat dormant for possibly more then 5 years. the motor looks super clean for how many km's it has and how trashed the suspension is. the car runs perfect but i can feel the 20psi loss as the car warms up.
i was thinking someone put a thicker head gasket on to drop the cr but that still doesn't answer the compression drop. its suppose to rise isn't it lol.
I've asked many mechanics and they cant explain it.
Hope someone can help!
Thanks.
https://www.sau.com.au/forums/topic/482142-r33-gts25t-compression-issue/
3 hours ago, blind_elk said:
Have you done a wet compression test?
Its a good idea, but it will confirm worn rings. The suspension didn't get rooted because the crackies drove it to church on Sundays. Or down to Supercheap for new filters, before the car wash.
Edited by Rusty Nuts
additional information
  • Like 1
hmm, its running 10psi atm, iv blown 2 turbos so far going any higher on the stock ones. Im still confused why the compression dropped 20psi just from warming up, and even more so why its 120psi hot and cold a year later. wouldnt it drop down to say 100psi once warmed up if its worn that much in the time iv owned it. if compression should be around 160-170+ and i have 120, shouldnt there be quite abit of blowby?
I forgot to take the crank case vent valve out of the manifold to get a true reading of how much blowby there is, i dc that. i took the catch can hose out and you can bearly notice air coming out, you have to squeeze the hose end and then its enough to feel like a gentle flow of air. 0 smoke. same if you give it a rev.
iv used the same comp tester for years to eliminate getting different readings.
Edited by JasonMate
    • I am well aware as I did rant at him to buy a MX5, buy the 2.5 before he DIY'ed it, etc as well as do things to the holden. He will obtain a ND. It's the best of both worlds. They look great in person, definitely the best looking one. Just a matter of time now.
    • Remember this is the same person who said he’d never own an nc
    • ouch! how is the car now?I had sold my gtr but have been looking into some on trademe and a 260RS but I wouldnt be keen on any repairs needed on them
    • This sounds like someone who would have owned an R33 in their past... It's okay, I'm 100% picking up what you're putting down Mark.
    • Just back on what was raised about jacking off the the tow/tie down point on the front of cars. I've used it plenty. I've also watched it on a car where you could see it move the front end of the car. It was like the front end/whole car being tweaked and twisted a bit. I will say, I struggle to find good jacking points on MOST cars. The ones that have good points, I then normally struggle to find a jack tall enough to make the car change height!   One of my go to points for either the jack, or the axel stands though, is either a suspension pickup point, OR a subframe to chassis major bolting point. I actually think its the subframe on my R33 that has a bit of a bend in it, from being jacked in the middle too. However, it could have been one of my many other cars I've had over the years! Or it could also be the from me jacking it up, and the fact the top of the front radiator support isn't there, so it can allow the front of the car to move and bend etc.
