I vote for Hypergear Turbos, have used 3 of them myself. Tao @hypergear is quite active on these forums.
I would suggest getting the ball bearing option, day & night difference from the journal bearing.
Be aware that a Hypergear turbo is not really a direct replacement from an engine management point of view. They make more boost and flow than the R33 ECU will be happy with. Talk to Tao about your options to keep the new turbo not so far away from the capabilities of the stock turbo so the ECU doesn't shit itself.
Then just get a @Toshi remapped R33 ECU (yes it is possible, only very select people can do it) for 1bar boost, FMIC, stock injectors, stock MAF, better fuel pump etc.
Should give you about 190~210kW at the rears.
  • Like 1
I have gotten contact with one who has a original Turbo, the rest of the engine is not original though. I have an Apexi ECU, biggee injectors and some stuff inside the engine.
Should have said so before. All our warnings and information about not going too big on the turbo can be ignored. A bigger turbo would be fine. Probably better to spend a bit more on something new rather than a stock ceramic time bomb.
Yeah but the thing is the car inspection does not like bigger turbo, i have an Garrett 34xx already but i want it to "look" original so it can pass inspection. So as soon as it has passed inspection i can swap back go the better turbo.
So i wont boost it more than 0.8 and map it to as close to original as possible then have a map with the better stuff.
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
