3 hours ago, Dose Pipe Sutututu said:
Here's an idea, buy a R33 GTS-t OR R34 GT-t, de-rego it and just store it.
Buy a P plater fun, stock car, enjoy it. Then once you're ready, sell and play with the whooshy break oil pump Skyline.
Sounds great but, I'll either be too tempted to take it out or it will be pushed out of the garage by my family at some stage. Although I could buy one 2 years into green ps...
1 hour ago, GTSBoy said:
Probably not budget compliant though.
r34 cost plus another car. unless I just stick to my corolla hatch🤨
This seems like something that would have been a good option 5 years ago - in today's climate it seems like a really really poor investment.
I honestly think unless you have some sentimental attraction towards Skylines - they really aren't that impressive a car. Don't get me wrong I wouldn't trade mine for anything and I have a massive soft spot for any Skylines I see (especially ones that are being tracked) - but if you're going in thinking about resale and how you're going to sell it in a few years, then unless it's a GTR I would stay well away and go for a more modern car.
  • Like 1
29 minutes ago, Binarydata said:
I brought a NA R34 a few years ago. Its a good fun 6k car. not a good 15-20k car. Def go something more modern
Kinda sucks the N/A's went up for no real reason...I'm a few years too late
  • Like 1
Argh, I do love Skylines...hope the GTT sticks around in 4 years on my opens then...
They've been around for 23 years, they'll be around in another 4 haha. Who knows what they'll be selling for though 🙄🙄🙄
  • Haha 1
  • 3 months later...
In my experience, get the car you can’t buy in 5, 10 or 15 years. I’ve had 32s, 180sx, xr8 and sold them all only to realise later they are out of reach due to cost or quality available. I’ve now got 34, got it 3 years ago before prices started going up and I’m slowly getting parts to turbo swap. Will be something I never sell and probably work on for the next 30 years.
  • 3 years later...
4 hours ago, tomaytown said:
Uhhh if anyone sees this - I bought a BRZ years ago, on my fulls soon so back on the market for the R34!
For a daily?
I guess you like constantly fixing annoying little things... Ha ha ha!
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
