G’day. I am about to buy a 370GT V36 Coupe, and I was browsing around the web for good modifications to make to the car. So far I have only been able to zero in on the UpRev ECU Flash. Other than that I am in all sorts. With the exhaust system, I am looking for something that’ll give a great sporty sound with not too much drone, as well as giving an additional boost of power to the car. And with the intake, I am looking for the one that can give the best performance. As you guys are knowledgeable at this stuff, I thought I’d shoot the question. Also any other mods that would make the car better would be much appreciated. Thanks
https://www.sau.com.au/forums/topic/482979-mods/
On 4/11/21 at 2:47 PM, GTSBoy said:
The best exhaust modification is a GT35 turbine.
Cheers mate! Only thing is it’s a bit out of my budget at the moment, was looking for something like an aftermarket exhaust system that sounds good, like the HKS hi power exhaust, and gives decent power boosts
https://www.sau.com.au/forums/topic/482979-mods/#findComment-7957412
20kW is not a "decent power boost". Barely noticeable.
I'm not suggesting that you don't spend (actually waste) money on putting an exhaust on it. But even the best extractors and exhaust only add a little power. The sound changes, which tends to convince everyone that it is going faster, even if it is not actually doing so.
You need cams, porting, plenum development, ideally more compression, etc etc, to make a significant increase on a modern NA engine. And almost no-one does any of that these days because it's horribly expensive relative to the gains.
  • Like 2
https://www.sau.com.au/forums/topic/482979-mods/#findComment-7957415
To be honest mate, exhaust wise I’m looking to get something that’ll sound really good, not that much looking for power, but if it can come with I’m cool with it. So if you guys would have any tips to make the car sound great and maybe even add a little bit of power, that would be perfect
https://www.sau.com.au/forums/topic/482979-mods/#findComment-7957416
Do headers, intakes and Uprev. Depending on the engines condition will see a small gain of maybe 15-25kw depending on who tunes it, will be a big improvement in midrange. Cat back exhaust is pointless and just makes horrible noise.
https://www.sau.com.au/forums/topic/482979-mods/#findComment-7957417
As someone who has done it before, don’t do headers unless you are flush with cash. Headers on these engines are quite good from factory. Intakes, high flow cats & a cat-back exhaust is enough for most people. Do your mods first then tune. Good luck mate & enjoy the rabbit hole 😁
https://www.sau.com.au/forums/topic/482979-mods/#findComment-7957428
If it helps mate Theres power to be made for sure, not to undermine people but the vq37 is underrated for NA.
Stock you'll put down about 190-195rwkw.
If you get headers, CAI, HFC and a tune you'll actually get about 230rwkw through an auto
We had a guy up here in qld get a Z1 VQ37 Intake Plenum and through the 5AT he made 236rwkw.
for me, i had just a Catback and CAI, Went from 195rwkw to 218rwkw.
  • Like 2
https://www.sau.com.au/forums/topic/482979-mods/#findComment-7958055
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
