It looks suspiciously like what they do cars that have been written off
They strip everything, then cut the shell
Does it have tags?
What does your local rego joint say about it?
Is it even able to be registered again?
I went and check through everything at the department of transport and it all comes back clean. The other shell I have had been written off. And yes I will weld the roof at some point. image.thumb.png.905bdedf6098028413669a2f5396e72b.png
  • Like 1
I dont really care about if it cost more than a good condition one. I have everything planned out with costs and everything. Plus I get to make it how I want it, not how someone else likes it.
I reckon you have at least 1000 things to buy for at least $ 50 each and let's say 10 things at 500 each. That's being very wishful and imagining you can do all the labour yourself.
How does that match up against your cost estimate?
  • Like 1
Sounds rational.
What's your current calculations and plans for the build?
On 08/06/2022 at 5:57 PM, dyl33 said:
Sounds rational.
Would cost me around 30 grand all up (Maybe a bit more).
Plans are:
Performance:
Built RB25 or Rb26 (Still deciding)
HKS Turbo
HKS Exhaust
Rays Wheels
6 Speed Manual Box
Exterior:
Top Secret Body Kit (Probably a replica as it is impossible to get original)
GTR Front End (Hood, Bumpers, Wings ect.)
Interior:
Standard apart from racing seats and Sparco Wheel.
I think that if it was that expensive I would just buy a donor car. And I have rebuilt a subaru wrx from the ground up before so nothing I have not done before.
On 08/06/2022 at 8:54 PM, Dose Pipe Sutututu said:
Man getting PTSD seeing that R33 in pieces, reminds me of my shit box.
I hope to see a twin scroll single turbo, with twin gates, and a Samsonas.
Yeah maybe
Plans are:
Performance:
HKS Turbo
HKS Exhaust
Rays Wheels
6 Speed Manual Box
Exterior:
You're off your head mate....
  • Like 1
Ok. I will be more realistic then.
RB25 DET With Mods - 10k
Interior - 1k
Body kit - 2k
Paint - 4k
6 Speed Manual - 3k
Other bits - 6k
  • Haha 2
Interior - 1k
Body kit - 2k
Paint - 4k
6 Speed Manual - 3k
Other bits - 6k
It gets better with every post👌.....
  • Like 2
The parts alone, from a very quick guestimation will be a huge bill, the car is a shell, and unless you are building a stripped out race car without a RB enfine, dash, interior, AC, window glass and powersteering the car will end up costing current GTR money, or more, and you end up only having a tacked together GTST
Me, I would sell the panels and csll it quits
Actually, that is exactly what the previous owner did, after stripping all the good bits, till all that was left was a chopped up shell
Step back and have a good think before you drop a house deposit on it
  • Like 4
I'm with these guys.
There is no merit in this plan. You will go broke, and you will go broke repeatedly trying to achieve anything with this car.
The costs that you think are realistic, like $1k for an interior, are just laughable. You cannot even find most of that stuff these days, let alone all of it in one hit. Anyone who has all of it in one hit only has it because they have it in a car that is too far gone to be saleable as a car. ie, it's all f**ked. And they will still want to sell the interior bits for >>$50 each, totalling $5k. And they will be all scratched up, faded, broken and f**ked. Did I mention the f**ked part?
  • Like 2
Alright guys you really have no hope in me but I do agree with what your saying. I will just build up the body (All panels ect.) and Build up subframes. Then I will go from there (Either selling or continuing the build)
Man, the time to build up a skyline from a shell was 5-8 years ago when the parts where plentiful and cheap. Anyone selling anything these days thinks it's made from gold.
5 years ago I bought a complete good condition R33 interior and boot trims minus front door cards for $50. Good luck even trying to find that stuff now.
Anyway, please post updates and can we get an ETA of when we will see a skid vid. Thanks.
    • This is for an RB20DET. Sorry for not including that.
    • Welp, this is where my compression lands after my rebuild. Thoughts? I have ~6 hours on the motor.
    • Well, after the full circus this week (new gearbag, 14 psi actuator on, injectors and AFM upgraded, and.....turbo repair) the diagnosis on the wastegate is in. It was broken. It was broken in a really strange way. The weld that holds the lever arm onto the wastegate flapper shaft broke. Broke completely, but broke in such a way that it could go back together in the "correct" position, or it could rearrange itself somewhere else along the fracture plane and sit with the flapper not parallel to the lever. So, who knows how and when exactly what happened? No-one will ever know. Was it broken like this the first time it spat the circlip and wedged itself deep into the dump? Or was it only broken when I tried to pry it back into place? (I didn't try that hard, but who knows?). Or did it break first? Or did it break between the first and second event of wierdness? Meh. It doesn't matter now. It is welded back together. And it is now held closed by a 14 psi actuator, so...the car has been tuned with the supporting mods (and the order of operations there is that the supporting mods and dyno needed to be able to be done first before adding boost, because it was pinging on <<14 psi with the new turbo with only a 6 psi actuator). And then tuned up a bit, and with the boost controller turned off throughout that process. So it was only running WG pressure and so only hit about 15-16 psi. The turbo is still ever so slightly lazier than might be preferred - like it is still a bit on the big side for the engine. I haven't tested it on the road properly in any way - just driven it around in traffic for a half hour or so. But it is like chalk and cheese compared to what it was. Between dyno numbers and driving feedback: It makes 100 kW at 3k rpm, which is OK, could be better. That's stock 2JZ territory, or RB20 with G series 550. It actually starts building boost from 2k, which is certainly better than it did recently (with all the WG flapper bullshit). Although it's hard to remember what it was like prior to all that - it certainly seems much, much better. And that makes sense, given the WG was probably starting to blow open at anything above about 3 psi anyway (with the 6 psi actuator). It doesn't really get to "full boost" (say 16 psi) until >>4k rpm. I am hopeful that this is a feature of the lack of boost controller keeping boost pressure off the actuator, because it was turned off for the dyno and off for the drives afterward. There's more to be found here, I'm sure. It made 230 rwkW at not a lot more than 6k and held it to over 7k, so there seems to be plenty of potential to get it up to 250-260rwkW with 18 psi or so, which would be a decent effort, considering the stock sized turbo inlet pipework and AFM, and the return flow cooler. According to Tao, those things should definitely put a bit of a limit on it by that sort of number. I must stress that I have not opened the throttle 100% on the road yet - well, at least not 100% and allowed it to wind all the way up. It'll have to wait until some reasonable opportunity. I'm quite looking forward to that - it feels massively better than it has in a loooong time. It's back to its old self, plus about 20% extra powers over the best it ever did before. I'm going to get the boost controller set up to maximise spool and settle at no more than ~17 psi (for now) and then go back on the dyno to see what we can squeeze out of it. There is other interesting news too. I put together a replacement tube to fit the R35 AFM in the stock location. This is the first time the tuner has worked with one, because anyone else he has tuned for has gone from Z32 territory to aftermarket ECU. No-one has ever wanted to stay Nistuned and do what I've done. Anyway, his feedback is that the R35 AFM is super super super responsive. Tiny little changes in throttle position or load turn up immediately as a cell change on the maps. Way, way more responsive than any of the old skool AFMs. Makes it quite diffifult to tune as you have to stay right on top of that so you don't wander off the cell you wanted to tune. But it certainly seems to help with real world throttle response. That's hard to separate from all the other things that changed, but the "pedal feel" is certainly crisp.
    • I'm a bit confused by this post, so I'll address the bit I understand lol.  Use an air compressor and blow away the guide coat sanding residue. All the better if you have a moisture trap for your compressor. You'd want to do this a few times as you sand the area, you wouldn't for example sand the entire area till you think its perfect and then 'confirm' that is it by blowing away the guide coat residue.  Sand the area, blow away the guide coat residue, inspect the panel, back to sanding... rinse and repeat.
