Anyone have any experience with these ?  https://artecperformance.com.au/products/artec-nissan-skyline-rb-exhaust-manifold-v-band-reverse-rotation
What got my interest was the 7.1kg, my last 6boost was solid 12kg.  Not to mention it didn't fit... wait i just did :)
I also like the off the shelf blanket option.  I've had real heat issues with my current setup.
The reverse rotation is a bit tits as it means new turbo and new piping.
https://www.sau.com.au/forums/topic/484276-artec-manifolds/
mine will be going on in the next month or so ish by March latest think by powers of deduction we might have same tuner also
unfortunately mine wont be back to back as im changing turbos also
Edited by bcozican
  • Like 1
https://www.sau.com.au/forums/topic/484276-artec-manifolds/#findComment-7973532
I've got one, just fitting up now...
I also opted for new studs and went the titanium route and access to the two lower front nuts is basically impossible with a conventional socket or ring spanner... Think I'm going to have to get creative 🙃
Haven't heard of anyone having this issue but I guess they are still relatively newish...
  • Like 3
https://www.sau.com.au/forums/topic/484276-artec-manifolds/#findComment-7973579
You can get two different sized titanium nut kits(different makers), can't tell from pics but I assume yours are the 12mm ?
Please keep posting pic's keen to hear / see all the good and bad !
Seems like you have a lot of clearance to strut tower, this is in the 32R ?
Also interested in seeing potential space for a new turbosmart straight gate
Also looks like so so much room underneath compared to a 6boost, not sure what you would use it for but I am sure the AC lines would appreciate it :)
Edited by Butters
https://www.sau.com.au/forums/topic/484276-artec-manifolds/#findComment-7973581
wasn't aware of the different sized stud kits 😕 These are from EFI Solutions...
Ye the clearance so far seems pretty good, tis a 32 GTR... Fabbing dump pipe etc. now...
I'm only running a conventional Turbosmart external gate...
Was hoping I'd get away with not having to move the Power Steering Reservoir but that was probably a tad naïve of me ;)
https://www.sau.com.au/forums/topic/484276-artec-manifolds/#findComment-7973587
Looks tops, nice to see a picture that isn't straight form Artec. I'll be interested to hear how you go with that front stud, looks like a bastard.
Mine is en route from Brisvegas to Melbourne now, but reverse rotation G30 turbos are out of stock. FFS.
https://www.sau.com.au/forums/topic/484276-artec-manifolds/#findComment-7973588
Bloody Black Friday sales got me, haha. In stock and cheap...ish
https://www.sau.com.au/forums/topic/484276-artec-manifolds/#findComment-7973593
17 hours ago, mr_rbman said:
very sexy...
will never understand why guys use those mesh flexi joints, bad news...
Yeah i agree, have seen plenty leak but admittely a while ago. They've got the proper baffled one on the wastegate pipe so not sure why they wouldn't use baffled version for both...?
https://www.sau.com.au/forums/topic/484276-artec-manifolds/#findComment-7973745
can only assume stock issues but if selling at a premium should only use premium parts....... just my 2c anyway
https://www.sau.com.au/forums/topic/484276-artec-manifolds/#findComment-7973748
32 minutes ago, Komdotkom said:
Speaking of stock issues, no reverse rotation housings available until March at the earliest for the G30's. I blame Artec, everybody got on board and now I can't get a turbo.
Talk about first world problems.
i was gobsmacked when i bought all my gear on the black Friday sales that everything was actually in stock...
https://www.sau.com.au/forums/topic/484276-artec-manifolds/#findComment-7973768
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
