Because I'm a sucker for punishment I bought another E90 but this one came with a less than perfect body and I'm keen to fix it.
This one isn't too deep and it looks like somebody has just hit it with a can of genetic silver spray paint. I'm assuming I'll sand the clear and colour and then fix with some filler?
I was going to try and pull these out with my puller but that bottom crease is hard! There is access behind but it's really tight. Might be able to get a PDR style pry tool behind.
Would love some advice.
Thanks guys
https://www.sau.com.au/forums/topic/484341-how-should-i-fix-these-blemishes/
20 minutes ago, Ben C34 said:
You take it to a crash shop and pay the money.....
don't know if you saw, but he bought a BMW, wouldn't be worth it to fix professionally.
I reckon do the same as Marty did on Kel's march super turbo; just get a vaguely similar colour spray can and shoot in the general direction
  • Like 1
  • Haha 1
Thanks all :rolleyes:
New boot definitely an option @The Bogan - about $300 for a good'un.
Its that guard though. Surely I can make it look better without taking it to 'the man'.
I agree with the new 2nd hand boot option. You could as you said in the first post sand/fill the guard. It's going to be tricky to get a satisfactory finish diy painting it. Maybe just get a quote from a shop to just repair that part and see if it's economical enough. If not, just sand/fill/smooth. Get a can of paint mixed up and watch plenty of YouTube vids on how to to a blend in.
  • Like 1
Doesn't need to be perfect. Its the 2nd family car after all and, despite my emotions, gets beat up a bit. :(
I was thinking a can of body colour and clear, sand, fill, smooth as you said and do a soft-edge spray job on it. Wouldn't be worse than it is now.
  • Like 1
Sounds like a plan.
If you're going to do the repair, there isn't any reason why you can't get it looking pretty much factory.
In no particular order -
* Get a good colour match paint. I've had really good experiences with VG Auto Paints: Automotive Paint Supplies.
* Use a proper 2K clear (it will have a button on the bottom of the can to release the hardener) and good quality primer.
* Take the time required to prep/repair the damage. Ensure the filler is 1000% perfect and smooth before painting, eg if the 2 part filler is giving you tiny pin holes when it cures, use a single step filler to fill the pin holes. You can't rush or cheat out this step, it takes as long as it takes.
* Don't try and blend the clear coat. You could blend the colour, but you might as well use the entire can and colour and clear the entire panel. The 2K clear will only last a few days once activated anyways so at least it will all get used.
* Have a good respirator. 2K paint isn't friendly.
* You'll probably have a pretty orange peel y result using rattle cans. Nothing 1000 / 2000 grit sand paper and cutting / buffing compound can't fix.
It really isn't that much more effort to get the factory result, you're already in there doing the repair, might as well make it perfect.
  • Like 2
That's brilliant, thanks @Murray_Calavera
Considering it's the rear quarter, that's a lot to repaint with the rattle can. I'm worried about my results. 😬
I do have an air compressor but spraying has always been something I'm a little worried about.
If I'm spraying outside is it only a respirator I need? I know you need a full suit when in the booth.
Really awesome advice, thanks!
11 minutes ago, PranK said:
Btw I have previously tried to spray a front bar in my backyard using acrylic and it sucked. Bad.
Thats the thing about painting in general. It sucks the first 200 times, and then you think it sucks the next 1000 times, but other people say "Nah its actually good!" at that point. There's not much in the way of shortcuts.
  • Like 2
Ohh it's the rear quarter :( I was thinking it was a front guard....
Can you upload another photo showing the entire panel?
What we need are natural body lines/panel gaps where you can stop spraying the clear. Ideally a panel gap. This is because blending the clear coat is not an option.
I'll post an example photo. Say the damage is the red X, then I would colour over the damage and re-clear the entire area in yellow using the body lines to hide the blend point.
If I'm spraying 2K, I wear a respirator, paint suit and gloves. A disposable paint suit is only around $30 so I don't see any reason not to use one.
I have a feeling your air compressor might not be up to the task, you really want something at least this size to feed a spray gun - https://sydneytools.com.au/product/chicago-hush150-silenced-150l-air-compressor
If your a bit worried about working on the BMW straight up, you could go to your local wreckers and pick up a cheap panel and use it to practice on first.
Once you're happy with the results you can achieve on the practice panel, you could move over to working on your car.
  • Like 2
Thanks again for this help.
Here's the entire panel.
There's a few other scratches and dings in front of the filler but it's all straight behind it. The shadow makes it look a little wonky.
This would be the cheapest way to paint it. Blend the colour over the damage and clear over the red highlighted area.
What you would do is back-mask using that body line. Here is a good example video of the technique.
Thanks again for this help, hugely appreciated.
Bloody car lost its water pump last night so its in the shop getting that and some rattly wastegates fixed for the next few days. Will formulate a plan of attack for the body when she's back.
  • Like 1
In for a penny, in for a pound:
https://fenderist.com/fe90001
budget and/or lazy option - maybe just get those over arch stickers that are body colour coded?
  • Like 1
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
