On 3/22/2023 at 5:54 AM, PonieBoi said:
Rears can tuck 17x9 +30 with stock arms (bought camber arms all round just in case)
20 hours ago, GoHashiriya said:
Looks really nice, good work
Except that it is clearly too low at the rear (and presumably at the front) and will handle like a bucket of puss. The suspension arcs are not supposed to work with the wheel pushed that far up into the well.
If you're going to run it that low then you really should be using different bushes to push the rear subframe up towards the floorpan as far as it will go, and drop spindles. Drop spindles at both ends. The GKTech ones are good, and you will need/want to use their upper and lower arms with them also.
Edited by GTSBoy
Coilovers are how they came out of the box. Only just got the car home today.
Got camber arms for front and back but don't really need them.
Got the car home for the first time in nearly 6 months.
Fresh kit, paint job and wheels.
Next on the list is chucking in a non hicas subframe which I'm in the middle of doing the gktech reenforcement plates on, and also will be looking at new injectors and one of mine has a leak.
  • Like 2
Now that I can go back to working on this thing. Back to trouble shooting.
One of my problems is the car doesn't like to start again after it's hot (hot start). I have to disconnect the fuel pump to starve the motor, reconnect and start.
Got the injectors tested and cleaned, pretty much all above board. Will wack them back in, take the car around to Jaustech (SA), get the hot start config looked at.
What GTSBoy was mentioning has nothing to do with if they fit or not while stationary.
At super low ride heights, the top and bottom arms, along with the tie rods, move into some very odd areas, where as the wheel travels up and down, it will actually start to turn left and right.
Low ride heights, end up with bump steer.
Perfectly fine if you have a show car, but if you want to actually be able to drive down the road and have the car NOT automatically turn left and right unpredictably (with no steering wheel input) then super low height won't work. Camber isn't the only thing you need to worry about...
I know what he meant haha. I've raised the car since then but the moment I got them out the box without adjusting them, that's how they sat.
  • Like 1
  • 1 month later...
Been a minute. Haven't really done much with the car. Just enjoying it.
Pretty much finished my non-hicas subframe.
Figured I'd re-enforce the tabs and mounts before it gets painted.
It's not pretty but for my first time welding, itll do alright haha.
dzvHClmW1EIEbTmayOdmR3dhNmQgbiJgETJkwb6a9lHkPhNIfT_Le6XklAvLcA1Dgah6yAXiyYp56vM6nhmd7wqnGCDX8UO-QXExDGh-T7YBuNUSudVh5x95_ZT9GQR1k1bqRMeyxp-XBhzKlI2gOw1iB7F6tkeZFCrUTniztHB7sF2-Zy31MjgJlL8floVZva_bD43qB4AAQZe3LopSrhFda6fwUW9rNF_CW7FYlvfZNFQ6B3iJfEJAx5zxpQq4kpY5rYJOMS8VvHDMmCEGVXaUFyqLkNpQ6nMM-xCnTULhIShIRJS5IFVkiiRqEkO_5f1ZXzftFGaNf223ATn6bRaIaJFey5LIhoJzZ5V5vnxzFhpZbFXt_p4mMQpdfD4N41tJDgiQqOl3hvKX_RUTemRqpSnl3zBxeMVrqeKAo7zGkkJa_EnVWMNbuAveq0_bl3n0GgldyPRyKRpwnSKPYlKQ5Zibr29njHfL6jTVnJbQivXm05G0EIBV1OJxRdS4lWUOzWMNpr-5p8iK1e_k52aQ6xGonPxpO8D_hiOvQG1Npv3Y-s9p2VVFl8a73LTKIEoTik5hgDpddS3KxDV2A8CoDVSYXWhTCGRD1hO30WmpFzc3-PQyI9igOIQZcxkLmIKkVPSvATLrBRusoc-YrJumY4l_DeeDIyeo8pszwTbt6nhRQEeg72yFJ8cZnzivTPWkT_lECkfzo-VvntwP0EK1ZyqPxwuS3PTlczbqizEVsXtspMarCb1Arg6J0JULaKmtvVhE0UhaHOeuzSJxphWrFHudYt1Cmnew9kNzypnFGhQ_xIxD1B7GL7l1w3KN46Ne6oqvA7Tj5t8ejlNluGWBfdueaE1rj9lcfTwk6CGaICc1YnHlNHZgiZKOVyG4ZcXH6xPhRSYU8cnX4Aqkryq5nBiP-8wVMGdIkTTNK-SmuxnOGQ=w1328-h1000-s-no?authuser=0
Pulled my knob too hard (haha) and shifter bushing became non existent. Went to get a gktech solid bushing from Sleekas and it turns out the bushing has worn that much, I need to get a new/not f**ked shifter.
If anyone has other aftermarket options they have used, hmu.
Turns out there are 2 different sized shifter balls, and therefore 2 different size shifter bushes - noting they might both have the same outer diameter where they go into the gearbox
Looks like R32 sedan is the smaller shifter ball
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
