16 hours ago, ACTIVE-LSD said:
Normal for R33 and R34. If the original owners in Japan didn't have a lockup garage then they were all parked on the street exposed to the elements. Rust starts inside out from the intersecting metal sheets.
Mine came from Hamamatsu, Shizuoka a region where it rarely snows and still have the same problem.  Best you can do is a band aid solution and wait until you fix it properly. Australia is essentially sub-tropical so rust shouldn't develop too fast.
The problem is- whats a band aid fix? And what's considered proper lol
Trying to stop it from getting worse = use fish oil
Band aid fix = wire wheel / light grinding to remove visible rust, use rust converter, reseal and repaint
Proper fix = you go digging and keep chasing the rust, all metal with rust is cut out. New metal is welded in. Seal and paint.
  • Like 1
  • Thanks 1
Summed it up nicely- thanks mate.
What product would be best suited to use to reseal?
1 minute ago, BigDogRB said:
Thought so- thanks, seemed like the obvious choice but the OEM stuff seems almost like it's some sort of plastic.
Here is an example -
https://www.3m.com.au/3M/en_AU/p/d/b40067001/
  • Thanks 1
AFAIK if you ask people that restore these cars all the time they say the R33/R34 have way, way worse rustproofing than the R32. Even before you account for issues like the strut towers holding water.
  • Like 1
  • Sad 1
Yeah. Comes out of a caulking gun/squirty thing, sets to a slightly flexible but very firm consistency, much like a plastic. And then painted over. That's why it's used on seams. It can handle the slight movement between different bits of steel.
  • Thanks 1
From what little I can see it doesnt look so bad, some clearer pictures of the strut tops will tell a better story as you can see them deform - from the rust underneath - on the flat spot of the plate nearest the strut itself.
As others have mentioned this will need doing at some point, even if your car is immaculate, rust will develop between the metal sheets around the strut towers.
Now as a reference , Garage Yoshida (famous Japanese restoration shop for R chassis) will replace the entire strut tower for around 600k JPY which I believe is about 6k AUD. Depending on the state of the area you might be able to get away with just replacing only top plates themselves which can be done for about a third of that.
Can it be done yourself? Yes, of course. But I would probably think twice if you've never done this kind of repair before as its pretty specialist.
  • Sad 1
Unfortunately they only make replacements for GTR. No love for ECR33 , ER34 :(
Is there a difference between GTR and RWD strut towers? I wouldn't have thought so. It's only the outer guards and the subframe/chassis rail mounting points that differ.
The AWD strut towers are apparently shorter. Kind of a shame their only reference available was the AWD part as supposedly the RWD version is easy to convert to AWD by trimming to fit.
  • Like 1
Interesting read...
I know my R33 has a couple of spots of rust (very minor, mainly boot floor, and a spot in the roof).
Towers etc were all good 2 years ago when it was given a rough spray...
And I kept this car < 2km from the beach for 6 years straight, it has spent another 4 years sitting in a paddock, including going 1.8m under water in a 2017 flood...
I'm just going to not look too closely in these areas moving forward...
Ah well, I guess it'd be a good reason to tube chassis the front end :P
  • Like 1
Just thought i'd update on my plan to address.
i've got some Sikaflex 227, rust converter, some rust proof primer, and a (hopefully) matching paint spray can. Went for DSD42 DupliColour.
Plan is to wire wheel all effected areas back to bare metal, to assess damage.
If it's very deep I might be in the shit- but if it's only mild/moderate, i'll be applying rust converter, wiping clean, seam sealing, priming and painting all effected areas, are stripping the rust off using drill + wire wheel
I also plan to soon paint the wheel arches or even full underbody to prevent any more water entering, as i'm assuming this is where 95% of the issue arises from, especially without guard liners.
Will update once i've done this. Planning on doing a bunch of other general resto work (headlight open + clean etc) so hopefully I can update within a few days.
  • Like 1
Have a think about what you'll do if it's case that as you chase the rust back with the wire wheel, you end up with a hole.
Hopefully the rust isn't that bad, but better to have a plan in place for if you find yourself in that situation.
  • Like 1
The top plate is the same though, right? As far as I'm aware of anyway, and that's the b*stard that causes the most problems.
I was going to recommend SR Autobodies (UK) for just the strut plates but it seems they have now shut. I'm sure Garage Yoshida provide strut tops only; I recall seeing on their blog a strut-top only replacement they did - it would be worth contacting them.
Edited by GoHashiriya
additional info
  • Like 1
Update: got a bit crazy.
Stripped, wire wheeled, sealed, primed and painted. The paint doesn't match super well, and I noticed the paintjob in my bay is uneven- is this normal? Some sections look almost unpainted.
Anyway- here is what it took to prep it all. Big mission!
!A616CE9C-B3F0-42FD-8183-99A74990FE4A.thumb.jpeg.377b4e955854dd75526d433d2b12d6f1.jpeg9DC682A9-9446-4C47-9AB0-7007DCFD8264.thumb.jpeg.9335f02a539c872f71d80390dadbb254.jpeg
  • Like 2
Nah top plate is different as others have mentioned. not sure about the sides though. Are you sure SR Auto bodies are shut down? their website is still active.
Nice looking good mate. how many hours did that take you? If you're fastidious with the colour difference, you can take off the bonnet hinge and get it paint matched in rattle cans by a paint shop. use matte clear coat as engine bay is not gloss from factory.
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
