43 minutes ago, soviet_merlin said:
For the mechanically challenged: How can one tell whether there still is a water/oil heat exchanger on the car or not? Asking for a friend ;)
What does it look like and where does it live on an rb25?
Look for this round thing stuck to your oil filter housing with two coolant hoses coming off of it. Basically every modern remotely high performance engine uses one to help regulate oil temps
  • Thanks 1
3 minutes ago, Murray_Calavera said:
Mine did that too. I replaced it with a non-cracked oem fan. Works well.
Yeah but at the same price the gktech is apparently 15% bigger in diameter and advertised to pull out 40% more air on rbs so went with that,
Well, if you've already got it then see how it goes for your use case. We can all pretty much confirm it's not as good as the stock fan, all we can hope now is that it is good enough for how you will personally use the car.
  • Like 1
9 hours ago, Dose Pipe Sutututu said:
Also why not G35-900?
Get a good thermostat, and don't skimp on the cooler. Get either Setrab or Earls or Mocal or PWR etc. Avoid the eBay looking one with great marketing and big branding. You know which one.
Excuse the mechanical ignorance but regarding the thermostat are you saying replace the oem one for a better one?
Do.you have any recommendations?
4 minutes ago, GTSBoy said:
He was talking about the thermostat in the oil cooler circuit.
OK sweet
I think I'm going to go for this one here with PWR oil cooler, taarks oil block and greddy oil filter relocation with built in thermostat
https://www.jdmgarage.com.au/shop/engine/cooling/oil-coolers/rb-oil-cooler-and-relocation-kit-v3-rb20-rb25-rb26-greddy-pwr-taarks/
1 hour ago, YD34GTT said:
OK sweet
Why do you want to get rid of your oil warmer/cooler in a street car?
  • Like 1
Well after the comments in the thread i did mention that I'll be looking to track the car maybe couple times a year, so everyone is recommending an oil cooler hahaha now your comment got me confused 😅
Oh my bad. What I mean is, you can have an oil cooler and keep the factory oil cooler/warmer.
The factory oil cooler/warmer will help bring your oil temps up after a cold start.
The Taarks oil block deletes the factory cooler/warmer.
This is a wise suggestion for a predominantly street/roll/drag car
1 hour ago, Murray_Calavera said:
Ahhhh ok so getting an oil cooler without the taarks oil block and getting these sandwich plate attachments is what you're suggesting ?
Ahaaa ok just did some reading some essentially the sandwich plate goes between the block and and the filter and it by passes the oil cooler system unless it's really needed, so essentially leaving the factory warmer cooler until it's needed
Am I correct in saying that?
Still learning a lot about my build so excuse the ignorance. That's why I love these forums haha
Another way to do it, is to use the Greedy relocation blocks, then make up your own lines and mount your oil cooler where you want it.
Alternatively just buy their kit, although it comes with a small-ish oil cooler, which would be plenty for your usage anyhow.
  • Like 2
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
