(context, my rb25det pull type gearbox was making a grinding sound on idle and when accelerating in the lower rev range but goes away with the clutch pedal in) I got a pretty hefty bill recently which I'm not overly happy about (only because the problem is still there), my mechanic told me a while back that the grinding noise I had in my car was the spigot bearing, long story short but he pulled it out and it looked like brand new, he said that it wasn't lubricated and ended up putting in a new one that was. I didn't think much of it, until I turned on the car went for a drive and noticed the car has the EXACT same sound, nothing has changed.
He said it had some noise which I have no idea what he's referring to and I told him that my gearbox was still grinding, when we went for a test drive he said it was normal. There's no way a grinding gearbox is normal. You can really hear the grinding if you're in a higher gear but your speed is low, I guess makes sense as the gearbox is working harder.
That's one issue, the other issue I noticed is there is a loud rattling sound especially when I start up the car and especially as I go up my driveway. Some other things to note is that the previous owner did a dodgy clutch install and also stripped one of the threads on the flywheel bolt which my mechanic all fixed up and put a new clutch kit in, which I'm not sure if that has something to do with it. I know a bit about the history of the car, it was definitely thrashed and tracked.
The car itself drives fine and doesn't crunch through the gears, there was wasn't much metal shavings on the gearbox. Do you believe my mechanic misdiagnosed my car? I'm trying to decide what next steps to take, I imagine I'll have to rebuild my gearbox eventually.
Edited by silviaz
https://www.sau.com.au/forums/topic/484997-did-my-mechanic-misdiagnose-my-car/
I don't think you can blame the mechanic. He replaced what he thought and what is a common source of gearbox noise. It could be internal gearbox bearings that are causing your noise. Would have been an even bigger Bill. These boxes are a little noisy at low revs high load. I had a brand new one in mine before I broke it and it also had noise at low rpm.
I'd just put up with the noise and don't load it up at low rpm. Gearboxe is trying to tell you it doesn't like it.
  • Like 1
9 hours ago, GTSBoy said:
Input shaft bearing, more than likely. More common on the skinny box, but still an issue on the fat box. Mine does it (groans and resonates at low rpm in higher gears).
Funny thing is I wanted that replaced but my mechanic said it's a rebuild at that stage, I wanted that replaced because from what I understand it's not deep in the gearbox.
Yeah, problem is would have been better to do it all at once but now I have to pay to pull out the gearbox again.
Weird to me how the mechanic didn't offer to just tear into it further at that point but that's just how it rolls with a lot of mechanics. They'd rather get the cashflow sooner than later.
Well, replacing a front bearing is not a "rebuild", nor does it trigger a need to rebuild everything in the gearbox. A dismantled gearbox with worn/aged parts can be put back together just fine. The only argument is whether the labour to do so is then considered to be wasted compared to doing a rebuild as well.
Nah this mechanic is honest and for him he has a more "leave it if it's working" approach. Not always ideal because if for example I didn't replace my rear main seal and it leaked then I'd have to pay him again to pull out the box.
Yeah that's what I thought, I thought if all he has to do is take off the input shaft cover and replace the bearing behind it, that sounds like a pretty easy job but I'm not 100% sure as I haven't been able to find much information on the process.
No it’s not that easy, you need to completely strip the box in order to get the input shaft out and press the bearing off it and press the new one on
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
