Hey all, I noticed on my car in the rain when I drive and if I give it a little bit of acceleration, the back end will start to kick out. Makes it dangerous as I can't merge onto an intersection safely, and if I give it too much gas my car will probably spin out. I know being rear wheel drive does affect things but was wondering how much of a difference semi slicks make compared to regular tyres? The research I did was mixed, saying semi slicks are more for drifting but the rep for the company said they can be used for both. I've also had a wheel alignment recently, and my tyres are near new.
Edited by silviaz
  • Haha 2
What tyres are you calling semi slicks?
Semis on front and back, or just back?
In saying that, you need to drive to the conditions, be gentle on the throttle
Have another set of rims with "good" all seasons grippy tyres on them for inclement weather or when your just cruising around
Think about the people that you may crash into and possibly injure, or kill, if you "spin out" driving on a public road in the wet, also thinl about how effective your braking is on a wet road with semi slicks, this is why I don't run motorsport type tyres when it's wet on public roads, the risk is to high
  • Thanks 1
It's all 4 tyres, they are these type tyres https://valinotyres.com.au/products/greeva-08d - so from what I've gathered you recommend I change tyres to get tyres with a regular tread pattern?
They are not semi-slicks, they seem to be a cheap long life tyre with some marketing
They have a 380 tread wear rating
The RS4"s on my SS have a 200 tread wear and are OK in the wet if you don't drive like a pork chop
If they are that bad in the wet I would bin them
I cannot see them actually being really good in the dry with that high of a tread wear rating, the RE003's on my Yaris would probably be better than them with a tread wear of 220
  • Like 1
Not a semi slick, they are a long life drift tyre. Marketing hype.
7 hours ago, GTSBoy said:
Who the f**k are Valino Tyres?
Run something decent, like AD09, RS4, etc. Something with ~180TW is good for the street without being too sketchy in the wet. I flog my car in the wet.
You also need a proper LSD.
Japanese drift tyre company.
The above listed are quality Semi Slicks and are great in wet weather.
  • Like 1
Ah ok, not sure why they say semi slicks on the website, the tread pattern looks like it? But yeah even if I give it a bit too much gas (which is not much) the back end will slide. I have to very carefully work my way up to speed.
Great in wet weather you mean for sliding or as in grip well in wet weather?
Read some stuff from tire rack in relation to dry and wet weather tyres
https://www.tirerack.com/tires/types/category.jsp?category=PERFORMANCE
If it asks for a area code, type in 90210 which is a area code for Beverley Hills
  • Like 1
  • Haha 3
5 minutes ago, Watermouse said:
Do you have a recommendation for a shop that does a good job of installing LSDs in our gtt around Sydney/Newcastle?
I've taken my cars/diffs to Smithfield Gearbox & Diff and my mates to there too.
They know their Nissan shitboxes inside out
Smithfield Diff & Gearbox
(02) 9604 8887
https://g.co/kgs/vtFyF8
  • Like 1
(02) 9604 8887
Awesome thank u so much mate
  • Like 1
Lots of good comments in this thread, I'll just throw this bit on top.
With semi's in the rain, there are a few things to think about -
* Getting temperature into the tyres is really important for making semi's hook up. Driving in the rain on a cold winter night will be very different to driving in the rain on a hot summers day.
* Semi's wear fast, tread depth has a big impact on how well they will hook up in the wet. Semi's don't have sipes so they need all the tread depth they can get to help evacuate the water.
* Not all semi's will work in the rain, regardless of temp/tread depth. Think Ventus Z214 vs Nankang NS2R. If you want to use them in the rain, I'd want to get some real world examples of them working in the wet first.
I've used Nankang NS2R 120TW year round in wet/dry conditions, in the rain on a hot summers day up here in QLD, it's a fantastic tyre. The best tyre I've driven on in the rain. I could actually put power down which amazed me.
On a cold day in the wet, they couldn't get enough temp into them to become optimal, however I wouldn't say they were dangerous. Think closer to a shitty street tyre rather then death trap lol.
I'd also say go with the advice above, get a set of good street tyres, something around Michelin Pilot Sport 4S quality level. Once you start making more power, you could consider going to semi's if you think the cost/performance ratio makes sense.
  • Like 3
Yep that's the one I'm thinking of getting, cheers mate! Great info there.
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
