9 minutes ago, Dose Pipe Sutututu said:
How are your valve clearances?
~0.3mm on intake and ~0.5mm on exhaust. These are the measurements I took via feeler gauges prior to reshimming:
Apologies, totally missed that table in the previous post
With not opening the TB all the way we found when do some pulls at 50% and 70% it was making more power/torque and only conclusion was the air speed was helping do that as was all same boost.  Setup was an old 3076 on modded factory manifold with a 45mm gate and Plazmaman plenum on stock runners.
Did you map the e throttle 100% to the 50%-70% in those areas of the map or was the increase in power/torque not worth going to the effort?
18 hours ago, admS15 said:
Most of this is above my understanding but I wonder if a 25DE NEO exhaust cam which are 6.9mm lift has somehow found it's way in there. Not far off your measurement.
I was seriously considering this and it would be a wonderful explanation/conclusion, however my camshaft is marked with U6. Photos online of a DET neo exhaust cam have U6, whereas DE Neo has U7, so I don't think this is the case. I went ahead and measured a few extra lobes and they are all 6.9 - 7.3 (variance primairly due to measuring error with adjacent parts screwing my caliper alignment). They really don't look that worn, so I'm disturbed.
Intake cam measures up perfectly normal, is cast with 'U8' (but it could also be U6, the marking is rough as guts), and the lobes are taller than on the exhaust (by about 1-2mm) just by looking at it.
Height 39.5
No description available.
Round diameter: 32.4; net lift = 7.1
Casting U6
It would have been too easy of an explanation of what's going on. I'm all out of ideas but I think you're well on your way to explaining it yourself with the low lift on that exhaust cam. I know that de Neo's with that cam when boosted still make good power but need a fair bit more boost to do it.
I wonder if anyone has some stock neo cams lying around to compare measurements.
  • Like 1
This is becoming something of a dark comedy. I will be spending some additional time in this relentless purgatory of R34 ownership.
Two days ago I noticed a pretty loud tinking noise from my engine bay at idle. After reassembling the car after my camshaft investigation, I went to track it down. Tinking coming from the turbo... it's f**king siezed when you spin by hand (but spins perfect (visually) when engine is on). Inbound removal and offloading to a turbo shop with clear instructions: fix.
Cherry on top, I started the car for just a second to confirm oil supply and discovered what turbo oil supply is like. Generous, in abundance, and over all surfaces great and small in the engine bay.
@Kinkstaah few more moments like this and I'll be on my way to saying damn it all to hell, lets put an LS in it.
Edited by CowsWithGuns
  • Like 1
  • Sad 1
Forgive me Father for I have sinned by proliferating misinformation online.
From the r34 service manual translated to English:
My cam nose heights are roughly in spec, and it appears the stock DET NEO lift would be at most 7.63mm (assuming a 32.00 round, I measured slightly above that). There is the open question why Tomei says the factory lift is 8.7mm. Begging someone who has some old DET Neo cams rotting in storage to whip out the ol' calipers or micrometer and present their factory high lift big boys ;)
Despite my turbo failure, my blade speeds were +/- 5% of what is expected from matchbot so during its one week lifespan I can only assume it was fine. And I made identical peak power on a much bigger turbo. My mate helped me do some more detailed data analysis and nothing seems out of place on the tune and sensor side.
Any ideas guys? I'm back to square one. I NEED A HERO!
Did you change the E-Throttle table?
Is the wastegate setup with correct preload? Ensure its sealing
Is the boost solenoid plumbed correctly?
Is the turbo a 7064 .92 rear? I have bought something and didn't check and was wrong housing but that early dyno chart shows is what I would think is lazy for this size turbo
Can you do some logging in 4th gear under load and also a trigger scope?
Do you know anyone you can borrow an aftermarket CAS like a NZefi or similar?
  • Like 1
Yes, no more hole.
Generous preload applied, 14 psi spring, added closed loop for full duty cycle on spool up (subjective modest improvement in spool). It's those new fancy twin port IWG actuators. The top port (pushing gate open) seals per air compressor test. Bottom port does not seal, air leaks out past the piston at a decent rate. My understanding is this is by design for safety - but since you mention it - I didn't confirm that it should behave that way.
Tuner plumbed it to his preferred way after I agreed to the recommendation to ditch my 4 port. It is done like so, except the tee is using the top port of the wastegate actuator (it has the option of two fittings on top of the membrane).
Is the turbo a 7064 .92 rear? I have bought something and didn't check and was wrong housing but that early dyno chart shows is what I would think is lazy for this size turbo.
Yes, placard on it states so :D
Unfortunately car is kaput until my turbo is repaired/replaced. Turboman called me today and said, 'you should come and have a look at this' with no further info so I expect to see a pile of shapnel for bearings on my lunch break tomorrow. I don't know what a trigger scope is, but I'll find out and do so once I'm back on the road. Here is some low speed 4th gear WOT spool data from what I have saved - this is at 0% duty as WG DC doesn't start until 2500 on this tune.
No, but I'm happy to buy one as it seems like an essential reliability upgrade anyway. I'm thinking of doing that and perhaps adding a cheap crank trigger while I'm at it soon.
Since my turbo did fail within a week and I have confirmed oil supply, did pre-oil with a syringe til it dripped out, it's plausible it was f**ked from the beginning and that may explain the lazy spool.
@Kinkstaah speaking off the ill fated 7064, feast your eyes on this.
What happened? Who knows. No sign of shrapnel in the manifold or the cat. Going to borescope the motor but I expect to see no damage. Perhaps the heinous noise I heard was the bearings flogged out due to getting sent to full boost on that unbalanced turbine dozens of times - if I want to engage my cynical side, this was already the condition of my 'never used' second hand turbo
This is my lazy boost explanation, heck maybe the exhaust gases were going into all sorts of chaos and losing me power too (but idk).
I've finished my sulk period and got my monthly pay, action time! Ordering Kelford 244As and shims, adjustable gears, replacement supercore, upgrade my triggering with something cheap and sensible. Get tuned under orders: 'give me the beans, boss' and whatever I get will be the finished build for this RB25 (except for maybe flex fuel so I can utilise the turbo fully).
  • Like 1
That compressor wheel has had a single solid object stuck in the scroll at the tight spot, knocked chunks out of every blade tip. The suggestion that it was already like that is probably valid.
A good reason to always rip the housings off and have a look when buying a used turbo.
  • Like 1
Just to muddle things up.
This is my GTX3076R compressor wheel which sounded great and was making 30psi and showed no performance problems.
So who knows what's gonna happen :D
  • Like 2
  • Haha 1
Could ya'll comment on this borescope image of cyl 1? Some of the others have shiny spots or larger brown areas, or shine 'cleaned' edges, but this one has these small marks on both edges where the valves are, that may or may not be small dents (hard to tell on my resolution). What causes this, is this likely to be shrapnel?
Dammmnn, gutted :( This definitely has a lot of potential to explain some stuff though... on the "bright side".
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
