Hi guys,
I've bought my first gtr and wanting to convert to a single turbo high mounted.
can people share what they have paid for their gtrs to be converted
in Perth looking for recommended workshops also
thanks !
1 hour ago, Dose Pipe Sutututu said:
Don't forgot to factor in the boring stuff too, like fuel system, electronics pack, clutch, etc.
That's only needed if you want to make sure it's all good, and safe, and reliable, and runs etc.
I reckon I could do it for farrrrrr less than these guys are saying.
Fab up a dodgy pipe to go from the twin exhaust outlets to one, a turbo from Bunnings for $400, then fab up a new outlet pipe.
I reckon I could do a high mount turbo for under $2k... Now whether the motor grenades when it comes onto boost the first time... That's a different question. And I'd hope, being a Skyline, especially a GTR, there is more put into it than a dodgy Bunnings turbo... :)
  • Haha 2
It will blow out fast.
$3k for turbo, could easily be a bit more.
$2k for manifold, at the lower end, and therefore likely to be more.
$1k for dump, could easily be more.
$1k for coating these things, really should be done.
$1k for desirable extras, like EGT ports, EMP ports, heat shielding. Hell, probably more like $2k.
You get close to $10k just for the main parts, without pipework fab, gaskets, fasteners, labour.
$15k is rock bottom. If you need intercooler, fuel system, clutch, ECU, you're pushing $30k. It is just too easy to spend money.
Call it $60k, to factor in a basic rebuild too.
Oil pump will go bang, and/or head will shit a shim and many sads.
Just build the motor at the same time as upgrading the turbo. Nitto oil pump, big ass sump, head to sump vent/drain, fix up all the flaws.
12 hours ago, thejacksta88 said:
Hi guys,
thanks !
Very open ended question.
the main things would be, what is already done to it, what is your mechanical knowledge/ are you paying for someone to do all the work? and what sort of power/ use for the car are you aiming for?
you could eBay all the parts and have it cheap and nasty or you can do it properly. (the first option usually requires you to do the second option later on to fix the mistakes)
realistically paying someone and buying all the parts without cheaping out is not going to leave you much change from $15-$20k depending on turbo, ecu and clutch choice.
Basically by the time you buy the manifold, turbo and waste gate then get all the fab work plus an lines for water and oil and add Labour it’ll come to 10-15
  • Like 2
11 hours ago, Murray_Calavera said:
What is already done to the car?
Hey mate completely stock apart from front mount.
I think I might stick with twin turbo set up and go upgraded turbos.
Exhaust - tune
I'm not after major power just something nice and responsive
  • Like 1
15 hours ago, Duncan said:
Yeah I agree, 10k give or take.
It'll go good after though.
Would you suggest staying with a twin setup but upgraded turbos  ?
Yeah, I probably would, because not everyone has that sort of coin to drop on a car. Depends if you want the last 1/10th of potential out of the platform
Plus, these days the cars are more like classics than a leading edge race car, so why do all that work when a nice pair of twins can still bring a smile
So guys I'm thinking I'll go
6boost manifold
gt35-900
50mm waste gate
full exhaust
Haltech platinum pro
Walbro 255
do I need to upgrade coil packs and would anyone suggest drop in cams  ?
1 hour ago, thejacksta88 said:
gt35-900
First up, I presume you mean a G35?
And...
Walbro 255
This is not a 900HP fuel pump.
and
Why would you do this to yourself?
and
Almost certainly. Time for some pencil coils.
It's money well spent, so long as you don't stay stuck in the 90s and consider something other than the usual Jap suspects.
6boost manifold
gt35-900
50mm waste gate
full exhaust
Walbro 255
You will also need bigger injectors.
your factory clutch will be living on borrowed time.
welcome to the rabbit hole that it skyline ownership
  • Like 1
Based on this -
and this -
6boost manifold
gt35-900
50mm waste gate
full exhaust
Walbro 255
My advise is to find a local workshop that is trustworthy and has experience building GTRs to the level you want to achieve.
Nek minnit the $60K I said earlier doesn't seem too far off the mark.
As an ex-skyline owner
Going off how these things are now "modern classics", I would keep the twins and just "refresh" bits that are required for reliable power and have a car you can take out for a cruise whenever you get the itch
As a idiot who cannot leave things alone
Going deep into the "rabbit hole" is a easy thing to do, as previously mentioned, once you start it becomes a slippery slope, wirh lots of supporting mods, and possibly rebuilds, and unless you have a bottomless pit of funds, the car can spend most of its life sitting in the garage,  broken, waiting for parts, or building more funds
For a classic like a R32 GTR
Basically, a reliable OEM+ refresh, that isn't a broken garage queen, is alot better than a car that you build, then break, then fix, then break again
And it isn't just the engine you need to worry about, these beasties are getting on in age, and all parts are getting, and have got, expensive, the days of picking up cheap replacement engines and other driveline parts are well and truly over
The funds not spent on going a single with quality parts, and with all the other other bits required to make it happen, could be spent on refreshing alot of other parts
A wise man once said "If you cannot afford 2 GTR's, you cannot afford 1", I also believe he said this about 20 years ago when you could pick up a clean R32 GTR up for around $20k
My advice for a R32 GTR (the one and only true Godzilla in my mind) is to think holistically about the whole car, the body, the power train, the suspension, the brakes, and the driveline
SAU is a wealth of knowledge with decades of Skyline experience,  from stock, to OEM+, to modified to varying degrees, to full on or weekend or dedicated racecars, as well as full on money pits that rarely leave their garage
Treat the old girl nice and give her what she deserves, you are a lucky man to own such a classic car
  • Like 3
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
    • Wrinkle black will be a thing for both
