Or @PranK could probably exempt the account realising it's a real human being on the other end of it.
Every Skyline now is a full resto mod job. It's more surprising when things aren't  falling apart and quite frankly I'm surprised when things are holding up. I'm often touching something working and remarking it's kinda crazy the condition it's in for 25+ years old when I see newer cars from 2008 etc falling to pieces.
I would not expect anything to work.
  • Like 1
On 3/12/2025 at 10:24 AM, GTSBoy said:
10 psi. 11-11.5 at the extreme max. Perfectly safe, just smoky, if not retuned.
Mine tuned and smokey on boost lol, though I do overboost past 13.5 psi if I really push it. Might need to get my turbo actuator inspected if it's jamming. Do you know if the map sensor can have something to do with it? I hear they tend to fail.
Edited by silviaz
You should not be able to see much smoke behind you if the mixtures are good - for ~13-14 psi anyway. It's not like you need to be running hell rich for only that much boost/load. Your tune might be a tad too rich. The tuner might have done that because they like to run a lot of timing. It's impossible to know what's going on from here.
It won't be the actuator.
It won't be the MAP sensor. Regardless of if by "MAP sensor" you mean either the Neo ECU's boost sensor (which is literally only that, a boost sensor so that the ECU knows a) that it's achieving boost, and b) that it is not overboosting) or you mean the dash gauge's MAP sensor (because it can't have any effect at all), or you mean the boost controller's MAP sensor (because it is very unlikely that it is running in closed loop, and so it is effectively just used to know when the pressure goes positive and so you can see the boost on the display, for the most part).
  • Thanks 1
Ok, good to know. I have open loop I think, I forgot which ones which but I am running the o2 sensor, brand new and I got a new boost solenoid because my last one was faulty and overboosting by a lot, but it's still technically overboosting. Haven't really bothered to hunt it down as I don't send it hard regularly.
Edited by silviaz
Overboosting is more likely a function of whatever boost controller you are using than the actuator.
"Overboosting" is a feature of cheap boost tee type control. If you don't want to see peaks of overboost, you have to set it to not produce them. And that then means you don't run as much boost as you might like elsewhere. That's just life.
Electronic boost controllers can generally be set to do a much better job of managing the peak boost.
Ah ok, my tuner did adjust something on the percentage cycle on the boost controller, instead of running at 40% the tuner put it on 20% to compensate for the overboost, can't remember what it was. Not duty cycle don't think, and told me if it keeps overboosting, it's going to be something else. I think he mentioned the turbo actuator.
On some cars like MR2 Turbos they're notorious for not letting the wastegate open far enough to avoid overboost, especially certain cheap downpipes. If adjusting "percentage cycle" fixes it then it's just an electronic control issue, not a hardware one.
  • Like 1
It sorta fixed it. It stopped it to boosting over 15 psi. But I think the tuner said, adjusting the percentage cycle was compensating for the issue.
On 3/12/2025 at 4:12 PM, GTSBoy said:
6 months since you bought it. 30 years since it was built!
You have to reach 10 posts first. One of our anti-spam anti-dickhead workarounds.
Oh no, I had already blew a turbo in June. I bought that second turbo and it blew it November LOL
Also yeah, that makes sense
  • Sad 1
On 3/12/2025 at 9:49 PM, PranK said:
I have removed the restrictions on your account @svenskalice
Usually this happens automatically after 15 posts but happy to do it manually when a new user has proved that they are a user. :)
Awesome, thanks!
Oh, also, found out why the turbo blew. Wasn't a bearing but cyl 5's spark plug had its ground electrode come off somehow. Not sure how it didn't f**k anything else up but I'm not complaining LOLIMG_0133.thumb.JPEG.2d2487b8daefddcea7cad53c2509498d.JPEGIMG_8243.thumb.jpeg.e03396e10cb4d44409b401339ddeabf9.jpeg
10 minutes ago, GTSBoy said:
Yeah., so whilst the death of that one was actually caused by other factors - it's still a 30 year old turbo. It's alrwady had a life. There are no new ones.
Yeah, true. Still sucks it lasted so short though, was planning to drive on it for another year or so.
Do a compression test, and a bore scope on the cylinder that lost parts of the plug. Chances are, that cylinder isn't so happy anymore...
The guy finishing my car did, cyl 1, 2, and 4 arent too happy, but cyl 5 is perfect. Don't really know how but I'm not complaining lol
