10 hours ago, Duncan said:
not really....in that it is possible but it would be easier to pull the motor than to take the sump off in the car.  It's not just that the diff is attached because you remove the axles and driveshaft, but you have to remove the whole subframe to get it out which is a heap of work including brake calipers and steering rack disconnected, have to support the engine from above because the engine mounts to the subframe etc etc
Also, at that point if the engine support stand slips I hope you can bench press 200+kg of RB26. Considering the oil pan has to be RTVed on as well which has like a 15 minute working time between the first drop coming out of the tube to fully torqued to spec I would probably never attempt pulling the oil pan unless the engine is on a proper stand.
You also have to pull the box out to take the sump off an rb26 because a few of the bolts are inside the belhousing.
just put something long and metal through the sump plug hole till it attaches to it and take it out through the hole
the real lesson to learnt here for everyone is don’t use cheap parts because they end up costing more in the long run
  • Like 1
That bit at least you can fit by drilling a couple of clearance holes in the sump webbing to get a socket in there
Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.
The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.
It was a victory for me last night.
B888CDB2-0638-4558-81F6-17B81FF17A3B_4_5005_c.thumb.jpeg.e88d524e5a5d2b9fdcca9ba4e0f1b0f4.jpeg    ACA7CBEC-9CDD-4846-9A55-F5E90AD3F304_4_5005_c.thumb.jpeg.74037927ee3da46f0a6f76dc2abe2b67.jpeg   48FD0092-F352-478D-BA2B-4C4811CC3FE6_4_5005_c.thumb.jpeg.c92090812617ef23179a495162a77c42.jpeg
  • Like 6
I have to say, I was briefly considering getting a magnetic drain plug but never could be bothered out of laziness/cheapness and now I'm very glad I didn't.
  • Thanks 1
Magnetic drain plugs are fine. Just don't buy cheap shit ones. They're actually better than letting magnetic shit float around in your oil.
The magnet also didn't just "fall out". OP was drilling the plug out which allowed it to come out.
Even some OEM plugs are magnetic.
I'm not doubting it does something, there's clearly a reason why Nissan bothered with it on the transmission/diff/transfer case but it's more just the effort of finding a drain plug that isn't going to have some unexpected design problem that makes me lazy. For example even the Nismo branded ones here spec way less than the factory 20 N-m. They say only torque to 10 N-m. That is getting absolutely trashed the moment you take it to any mechanic who isn't familiar with the specific requirements and assumes it should be torqued to factory spec.
  • Like 1
I thought you didn't let mechanics, especially those with no idea, work on your car any more? Wouldn't that mean it won't be an issue in your case?
Sure, but why assume that will be the case forever? And why assume you'll be able to do an oil change to swap back to a stock drain bolt before that happens? And does it even matter when I change the oil at fairly short intervals? Life can be funny sometimes and unexpected things can happen. Like breaking a collarbone so you can't do any work on your car for a few months but the oil change is due so you have to take it to somewhere and hope they don't do something stupid like stacking the new drain plug washer on top of the old one.
  • Haha 1
Looking back, I’m pretty sure I over-torqued the magnetic drain plug because I was trying to fully crush the copper washer. In hindsight, I definitely should’ve used a torque wrench.
Either way, I ended up switching to a regular drain plug so I don’t have to deal with this kind of issue again.
Big thanks to everyone on the forum for your support—I actually talk about you guys to my friends and coworkers
  • Like 1
On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
Your friend:
well-someone-messed-up-v0-rwkaynhp8paa1.thumb.webp.44cebc43a7f9e36c5b7795509d05bd8b.webp
Not my proudest moment, but about 6 years ago, i did an oil change on my ex-gf's car while drunk. It was a Toyota Rav4 so they had a weird oil filter holder device that's not the standard oil filter. I went to start up the car and drove it from the driveway to the parking spot and i turned around to see the biggest oil spill i ever seen. It didn't end up being a problem because i filled the oil back up and tightened the filter properly, but after that experience i never worked on my cars drunk.
  • Haha 3
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
