Yes many wonder and think we are cheating, and well yes we are. I thought to disclose some of our secrets of our zed tt race car and why it goes so well. Yes Nissan make some things universal to different family of cars and engines as we have found over the years of checking. My zed actually has quite a few GTS-T and GTR bits including.
Nismo GTR bushes in diff and control arms. Nismo don't make much for zeds adn don't even know that some GTR bits fit zeds as not listed in their catalogue.
R32 GTR Cusco upper rear adjustable control arms. A bit heavy though soon to go chromolly custom.
Modified NISMO R200 R32 GTR diff centre with R32 GTS-4 crown and pinion 4.375 ratio. About 20 kilos lighter, much better ratio than the heavy zed 3.7 which is also a slushy viscous coupling.
Tomei GTR solid lifters, valve springs, retainers and shims. converted from hydraulic lifters similar to RB20 and 25. Solid lifters seat better at higher rpm and accommodate custom cams.
Turbo's are similar to N1 but are actually new 200SX S15 ball bearing.
Soon to have N1 silicon crank and cam seals, yes VG and RB same here and N1 stand more punishment with heat I guess and are orange in colour.
Did have R32 GTR water pump pulley with holes drilled to suit 300ZX 4 stud viscous fan. Being larger but same offset and belt size, this slowed the water pump down so it did not cavitate as much at high revs. I now use electric water pump and thermo fan.
Motor going back in next week with R33 GTS-T lighter alloy power steering pump rather than heavy zed NA cast iron one I have been using. Yes thanks to Nissan bolts straight up other than high pressure hose so getting this moded to suit.
Nismo R33 GTS-T gear box mount. New alloy light weight body rather than steel factory one, and is also stiffer for better throttle response and less energy loss.
Nismo 555cc RB20 top feed injectors with custom fuel rail that sits above factory plenum instead of below the plenum. Instead of factory side feed. Also was able to use custom alloy high flow fuel rail, and open up engine for better cooling as it keeps the fuel rail out and away from hot engine block and heads. Plus as a bonus the injectors were incorrectly ordered by a customer a few years back and I thought may as well use them.
R33 GTR accelerator peddle which has a bulge at bottom for heal toe. No GTS-T's don't have and YES GTR peddle also goes straight on and only about $15 from memory.
I am sure this is not the end of it and it does seem to keep happening.
Lots of other parts fit such as R32 or R33 GTR brakes but went 6 piston.
Zed and R32 GTR have same gear box by they way. As in the middle bit with the gears that is. Lots of other bits I won't go into here. I have only listed what is better for zed.
Not sure what Zed bits a GTR would want other than AFM and motor.
OK who's first Skylines Rule etc etc.
https://www.sau.com.au/forums/topic/49063-zedtt-race-car-with-skyline-bits/
Bottom end is built and the rest of the motor is going back together over next week, then she goes in. Did a few mods such as custom cams with 10 degrees more lift, extrusion honed the factory exhaust manifolds and did some match porting and a few other things. It has a big SKYLINESAUSTRALIA sticker on the back maybe a GTR sticker on the front hey?
Duncan how is your GTR going and are you coming to our track day for the big GTR v ZED challenge?
Ummmm I think my Skyline has something from a Zed... Ummmm Ummmm , let me think.
Oh Yeah - I remember.........
The Nissan Badge.
JP I don't know why you go to all the trouble of making your VG more like an RB - just put the RB26 DETT in it and be done with it mate. Will save you heaps of the R&D you are doing that prooves RBs are superior to VGs and VQs.
:cheers: he he ;)
Well there have been a few conversions to RB26 into Zeds which is backwards wondering if anyone would go the other way. Big prob is the 4 wd set up.
The new generation ALLOY block VQ30 is the way to go which many of the Jap GTR GT500 Circuit cars are using.
pfft don't worry about the small VQ30 go straight for the big block VQ35 ;)
They are expensive and hard to get but looking into stroking the VQ30 to VQ35. Getting info from Nissan re this, probably same block just different sleave, pistons and rods. We will be getting ARGO rods anyway and forged pistons so no biggy there. 100 kilos lighter with more HP and torque and maybe two Disco Potatoes and wacko probably 450rwkw with out too much lag. The new Nissan range is strong, nicley balanced and not only much lighter but much lighter rotating mass. We pulled appart a VQ30 NA that we are using as a jig and as a test we weighed the scond hand pistons and rods together, not cleaned so had some carbon and oil, the maximum variations was .5 of a gram. To give you an idea this is one small posted note. That is VERY good. A workshop near us was rebuilding a 350 Chev V8 boat anchor Commodore motor and just pistons alone were 8 grams difference and they were new.
  • 3 weeks later...
Also has R34 GTR rims on it thanks to Steve at Just Jap which we used at Drift Nationals. They realy suit the car and the GTR badge on the centre caps look the part. We actually used a VQ30 all alloy power steering pump on it. Not sure if I mentioned but it also has R32 GTR Nismo diff mounting bushes.
I imagine you have passed a casual eye over this animal...Autech Tsukada Z32, basically VQ35 with HKS 3037. I like the idea of twin GT28s better.
Hope UAS go thru with it, when i win Powerball ill pay for the container over to Japan with some Aussie built cars, could even perhaps surprise a few ppl
    • Need to see other side of PCB in that area...ie; I don't see any thru-hole mounting, just soldered vias (smd zeners in SOT23 have 3 legs but only 2 are used, as reflected by PCB tracks)
    • 4 to 5 is fine. It will be slow, but that's better than blowing turbos. I don't have a PS pump idle up solenoid on my car, because... I think when we put the Neo in we retained my R32 lines. But.... From inspecton of the R34 vacuum hose diagram, you can see that the solenoid needs to be connected to the turbo inlet as source of clean air) and the plenum (as source of vacuum - which is the place for the air to flow to to cause the idle to increase). So 3 to 1 is VERY WRONG. 3 should go to either the turbo inlet, or the plenum. Follow the other hose from the PS solenoid and if it goes to the plenum, then your 3 goes to 2 2 would also serve as a bleed port for a boost solenoid.
    • Pull them out and pull more apart. You can't do shit with them still bolted to the floor of the car.
    • Yes it is. ZD1 is on the other side of the board. Where ZD1 is marked is clearly opposite a 2 pin device. Our 3 pin device here is not a ZD.
    • Alright, a little update on this... I called Fulcrum, who used to be the distributor in Australia. No Bueno, they don't service them anymore.  Called shock works, who don't service them but offered to dyno the shocks for performance, and suggested DNA in Sydney might service them.  Called DNA, who also do not service them and basically said they try to steer customers away from tein for this exact reason these days- there is just no support for them anymore apparently.  Both SW and DNA said they are a not necessarily a bad product, but they just don't service the brand or know anyone who does service the brand anymore.  So... I could keep calling around but at this point I think I'll probably just spring for the shockworks product, unless anyone here knows anything.  Cheers 🍻
