i just thought i would start a thread for people to throw up their dyno sheet and a list of major mods so people can compare and enquire what make a good improvement and what doesnt and to see how laggy certain turbos actually do make the ol rb engines....
i have :
lt12 plug in microtech ecu
gt28440hp bb turbo (t25 flange)
600x300x76 modified hybrid cooler
malipassi reg
480cc injectors
bosch 909 pump
3 inch exhaust with custom dump pipe and no cat
adjustable cam gears
profec b spec 1 boost controller
im especially keen to see guys with rb20 engines and turbos like 2530,2540 etc
my graph can be seen here.... http://www.skylinesaustralia.com/forums/at...achmentid=21307
low boost (8 psi) hi boost (18 psi) cheers Jon
https://www.sau.com.au/forums/topic/49209-post-up-your-best-dyno-graph/
  • Replies 223
Posted Images
My R33 is still pretty stock but i have dyno figures for it.
it has-
- a front mount intercooler kit by Hybrid.
- a custom made double dump pipe by Drift King.
- a turbosmart boost controller switchable hi/low boost.
- 3 inch exhaust.
it makes max power at 6400rpm at 9 p.s.i.
http://www.skylinesaustralia.com/photopost.../cat/500/page/1
heavily modified (engine just been refresh when the turbo and cam shaft fitted)
Apexi RX6 high-mount turbo
Apexi exhaust manifold
Apexi external wasgate
Apexi cam shaft
Apexi valve spring
Apexi fuel pump
Apexi injector
metal head gaskit
ARC front mount intercooler
Full trust exhaust system
Blitz dual sbc boost control
z32 air flow meter
Just Dyno the car at Dyno source and it made 392hp at rear wheels in 1.3bar(pump fuel)
should make 430hp at rear wheel in 1.4bar with race fuel
on the dyno graph still show car run very rich at 392hp at rear wheel in 1.3bar.
This is my current set up, im pushing my injectors a little though, need bigger injectors
gt2535 turbo
600x300x76 hybrid cooler
bosch motorsports fuel pump
Bleed valve boost controller
215rwkw on 18psi
Dyno paper i will post as soon as i can get it scanned
I saw merli's 600.1 rwkw graph...but he claims to have "lost" the pic now.
here is mine from the SAU Dyno Day today :(
Apparently it was running too rich, so we should be able to get the extra .3 rwkw with some tuning :D
I'd love to know Paul's secret to 450HP. I'm nearly there - with similar turbo (larger rear housing). Dude did you have an exhaust on your car when you got the 450 ?
This is 23 PSI - ( get no difference in power from 21 PSI upwards - tried 25 PSI today and 2 rwkw less - same dyno)
GT30 is pretty ambiguous as to the size of the turbo, the GT30 family is huge. Then again, it could have a '30 rear, and a larger family compressor. Such mystery!
ps. 450 hp is 335kw, different dyno could accomodate such variation.
Edit: You can't compare the A/R directly between Garrett vs HKS - different designs where the HKS units have a smaller radius ®, so the area (A) could be the same on a larger HKS vs smaller Garrett.
Edit2: You would probably find that you can drop the size of your turbine housing B-Man and not lose horsepower.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
