  • Replies 198
Hey .75 degrees sideways. That looks totally crazy!!!! I love it.....especially the rims!
How did you go fitting the 6 cyl into the pintara seing the rear cross member mounts in a pintara are different to a skyline?
thanks R31Jet. I must say i'm equally impressed (understatement) with your r31 mmmmm rb26 :wassup: About the crossmember mounts, I didn't fit it myself. So i'm not too sure how it was done. I haven't really noticed it. I'll have a look later actually.
Just wondering how much did you pickup your 2535 for? how much power is she putting out at the wheels? got any more pics of your 26r31? :cheers:
2535? What U mean by that.
She put out 234rwkw at the melbourne auto salon with the engine totally stock.
As for any more pics...Unfortunately I dont have any on the computer.
:boobs: :boobs: :boobs: :boobs: :whackit: :whackit: :whackit: :whackit:
Car: hr31 gtsx
Year: 1988
Purchased: 10 mths ago
Mods:
r32 gtr motor
rebuilt 700km ago
forged pistons.. the usual n1 parts
5 speed (r32 gts)
(280 km/h speedo fitted)
GTR front mount intercooler
TRUST oil cooler
full silvia s13 coil over conversion
R32 GTR front and rear brake calipers and rotor
Front and rear strut tower braces
7-point roll cage
Bride driver's seat
BLITZ dual solenoid boost controller (SBC)
R31 GTS-R front and rear spoilers
KTS exhaust with front pipe
HKS BOV
16" r32 gtr wheels
Aftermarket steering wheel
Twin airpods
Aftermarket shift knob
cusco 2 way lsd form a silvia
recently resprayed in a black fleck paint
east bear bonner and mirrors
short shift
a tonne of other stuff that i cant remember
set up for circuit sprints
Car: hr31 gtsx
Man......Did you do the suspension conversion yourself?
I have been looking into doing that for a while now....I have measured it all up and was trying to work out the front knuckles...
i think he used the s13 rack, and thus the s13 arms/knuckles etc theres a thread made about it in general discussion on the r31 site
yea one car i used the s13 rack control arms and everything
other on i use the r31 race with a longer threaded section for the extra distance
yeah......that is what I was gonna do...I was gonne use the S13 control arms and all that....but the R31 rack wont fit? I have a non power steer rack. and I dont think there would be a non powersteer rack for the S13.
interesting non power steering
you can get the steering rack arms modified if you liek basically they add a longer thread to the end of them
pete
Where did you get that done?
I prefer non power steer. Less crap loading up the engine, cleaner engine bay and I have found the aussie power steer system to get fluid hammer when you quickly change dierction, like doing a slalom in a motor kahna, so the non assisted steering is better to use for it, plus it has niice feedback on the road.
any machine shop can do it however i got mine through powerplay (r31house) who have them costom made
power steer realistically doesnt remove dick all power from you engine.. aybe 1-3 kw
plus it makes it easier to steer
i think ausi power steer suffers from dodgy rack and seals which cause leaks
hr31 rqack leak cause of the amount of conections in the 4 wheel steer
s13 racks are a proven quantaty and are esy to exchange so are a god move
pete
R31 GTS-R
RB25 - fully rebuild bottom end, forgies, gtr rods etc
GT30 600hp/45mm ext gate on the stock GTS-R manifold.
ARC I/C
Nismo 740cc injectors
PowerFC
R32 GTR brakes - 5 stud conversion
R32 & R34 GTR wheels
bilistein coil-overs with adj strut tops
you get the idea, heaps more on it, and always more stuff coming.
looking at some serious brakes... 33-t gearbox and a few other expensive things :Oops:
270rwkw @ Racepace on 16psi, should get to 300 with some boost.
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
