  • Replies 409
Yeah it gets worse. 7 of those 10 have aftermarket turbo's! All making over 300 at the wheels. LOL.
The last Maserati Day I went to I left thinking "I need more boost!"
I can feel that thought coming on again! LOL.
hahaha im going to rock up and watch and do some filming... are u allowed to spectate? im going to bring 2 cameras.... does anyone have a headrest camera mount?
I would be honoured if you care to put your spare cam in my car! :) Havent got my camera down here with me so cant film my track days anymore :D
Do these moster GTRs all run sticky rubber, good brakes... :Oops: looks like a hard day at the office if the old R32 is going to register a time. :Bang:
yeah no worries... the other cam i will use to film from the sideline so we can have outside and inside views... then when snowys pitted we'll swap em over...
do u have a camera mount?
Nark, I have a camera mount that fits R33 GTS-ts - clamps onto the headrest risers...
If anyone wants to use it feel free... I can't on the GTR now
Andrew - yeah I figured that track day insurance would be impossible.
Trying to convince my mate to bring an E46 M3 to this day too :)
yes please!!! that should fit the 32 just fine...
sweet... btw can someone passenger me on one of the training rounds? i wanna see what its like on a track.. i know u cant push it in those sessions but im not worried about that
Hey Guys,
Finally looks like I'll be able to join you for a track day....yay!!! Just got a quick question before I fill in the form or confirm whether I'll be there or not......Reading the form it states you have to have a exhaust system that complies with the '75db drive by test'. While my exhaust is an aftermarket HKS system it isn't all that loud....how much leeway do you get with this???
mate - you'll be fine. Your car will be a lot quieter than a lot of the the other cars there I garantee. The +300kw GTR's dont have a problem. The '69 Mustang with the 7.0L donk thats louder than any skyline Ive heard doesnt have a problem. You wont have a problem with noise.
did it state somewhere in the requirement, "measured 30m from the side of the track" ?
so in other words, cant really compare the normal epa 90db noise test which is done at 1m 45deg angle. i was told many exhaust that is over the 90db noise test limit above will still be under 75db from 30m away.
Great......in that case can you guys add my name to the list. Am 95% sure I will be there just give me a day or so to confirm the requirements for my car etc.
Also whoever is organizing this (Snowman / Roy??) can you PM me a phone number to contact you on as getting on the net at works a bit of a hassle.
Thanks
You can use it - I built it (!) and has a Manfrotto camera head on it - super stable... I just have to find the quick release plate to put in the bottom of the camera.
I assume that th 32 and 33 headrest uprights are the same width apart?
-Marcus
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
