  • Replies 409
Yeah it gets worse. 7 of those 10 have aftermarket turbo's! All making over 300 at the wheels. LOL.
The last Maserati Day I went to I left thinking "I need more boost!"
I can feel that thought coming on again! LOL.
hahaha im going to rock up and watch and do some filming... are u allowed to spectate? im going to bring 2 cameras.... does anyone have a headrest camera mount?
I would be honoured if you care to put your spare cam in my car! :) Havent got my camera down here with me so cant film my track days anymore :D
Do these moster GTRs all run sticky rubber, good brakes... :Oops: looks like a hard day at the office if the old R32 is going to register a time. :Bang:
yeah no worries... the other cam i will use to film from the sideline so we can have outside and inside views... then when snowys pitted we'll swap em over...
do u have a camera mount?
Nark, I have a camera mount that fits R33 GTS-ts - clamps onto the headrest risers...
If anyone wants to use it feel free... I can't on the GTR now
Andrew - yeah I figured that track day insurance would be impossible.
Trying to convince my mate to bring an E46 M3 to this day too :)
yes please!!! that should fit the 32 just fine...
sweet... btw can someone passenger me on one of the training rounds? i wanna see what its like on a track.. i know u cant push it in those sessions but im not worried about that
Hey Guys,
Finally looks like I'll be able to join you for a track day....yay!!! Just got a quick question before I fill in the form or confirm whether I'll be there or not......Reading the form it states you have to have a exhaust system that complies with the '75db drive by test'. While my exhaust is an aftermarket HKS system it isn't all that loud....how much leeway do you get with this???
mate - you'll be fine. Your car will be a lot quieter than a lot of the the other cars there I garantee. The +300kw GTR's dont have a problem. The '69 Mustang with the 7.0L donk thats louder than any skyline Ive heard doesnt have a problem. You wont have a problem with noise.
did it state somewhere in the requirement, "measured 30m from the side of the track" ?
so in other words, cant really compare the normal epa 90db noise test which is done at 1m 45deg angle. i was told many exhaust that is over the 90db noise test limit above will still be under 75db from 30m away.
Great......in that case can you guys add my name to the list. Am 95% sure I will be there just give me a day or so to confirm the requirements for my car etc.
Also whoever is organizing this (Snowman / Roy??) can you PM me a phone number to contact you on as getting on the net at works a bit of a hassle.
Thanks
You can use it - I built it (!) and has a Manfrotto camera head on it - super stable... I just have to find the quick release plate to put in the bottom of the camera.
I assume that th 32 and 33 headrest uprights are the same width apart?
-Marcus
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
