HEHE I love the attitude mate.... I think if I didn't have you around I would be too scared to do 10/10ths in my car. When I see u pushing it in your 100,000+ car it makes me not worry too much about my 37000+ car.
  • Replies 409
I actually found that taking it a bit easier and rolling third gear at Dandenong and through the final series of corners was a bit quicker for me. Even at PI through turn 8 (after Lukey) 3rd was a better option than trying to force 2nd and control wheelspin out of the turn.
I won't believe you will just sit on it snowgander. It's not in you.
sweet.. jack u gonna take ur truck? if i get bored i can watch som DVDs :rofl:
Definetly bringing my car on the back of the truck.....
DVD's will be ready incase you get bored, which most likely you won't.....
put that GTR special on when that german dudes fanging around the nurbirg ring ion ur DVD player in ur car hahahaha get some tips and encouragement as ur going around :D
:headbang:
If he is bringing thr bbq then he has to keep the proud fatz tradition alive of doing circle work on thr grass at sandown with the barbie slapping around in the boot and event organisers telling him to stop over the PA...lol, fatz always provides those kodak moments:thumbsup:
I dont understand?! How can you have soo many problems with your car Roy? Seems like everytime you post, somethings wrong with your car, your engine or it's "in the workshop" getting fixed... wtf? Does your car ever run? it just doesnt make sense to me... :headspin:
Hey guys....are we expected to hear back from the masterati people after sending in our app?? I sent mine in weeks ago but still haven't heard anything.
Roy,
I second inasnts question 'bout the bonnet straps too :)
Roy,
Yeh they arent bonnet pins, but it is a secondary restraint, and YES if you want one then i will have them ready, i will have them the Sunday before Sandown so that we arent rushed.
My car is doing strange things, dont know why, but it ocntinues to play up. Engines miss, idle probs then there are a bunch of cosmetic concerns which may only be cosmetic but if you think about their intended funciton then they can impact on the relaibility (possible damage).
So i will be busting my balls trying to get the thing over the line, no doubt so will the ever patient mechanics but im hoping to make it rather then confident of making it:cheers:
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
