spotted a white 35 stagea on south road @ reynella about 12:30 today looked good
spotted a silver c34 stagea @ sherrifs road just after that and then another (may be the same) silver c34 turning off south road @ hackham
Spotted a silver m35 at wakehurst parkway and warringah rd intersection bout 12:45pm today then another baby blue M35 at pittwater rd allambie just after.. I had to give it a bit while making the turn onto pittwater rd as there was a ute coming... When I hit the bus lane the old surface was a little greasy so got the dance moves going.. Caught me a little off guard that's for sure..
I'm not a hoon.. Only when I'm in a rush to pick up the wife you know how it is.. Can't be late!!
Spotted yesterday, white series two on Botany road in Alexandria in the morning and another white series two on Carlingford road in Sefton in the evening.
The one in the morning would have been me if it was around 10-11ish
My boss said to me this morning:
"Do me a favour, whatever you do, don't put a huge spoiler on your car!"
He claims he saw a white M35 with "huge bodykit with spoiler" which looked like ass.
Not sure if he's getting it mixed up with a C34...he's been in my car a few times so he *should* know the difference, LOL...
    • I'd be worried about having to parallel park a boat like that. Magnificent car though.
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
