Spotted a black NM35 (neither Jetwreck nor Daleo) on Queens Rd near the Five Dock recreating centre around 5:20pm yesterday.
Waved but the male driver didn't see me as the sun was in his eyes as he was going west.
So I have been in Japan since 7th October with the sole purpose of joining the Prince Skyline 2000 GTA&B Club on their overnight drive from Tokyo to Toba (Mie Prefecture) and whilst here have been keeping my eyes open for the 'spotted' thread. Let me tell you...there are f.ck all Stageas on the roads here. The Club drive was 460km each way so i though i would definitely see some. Here are two snaps of the only Stagea's i have seen and both are M35's.
1st one is was on the Tomei Expressway (from Tokyo - Suzuka) and just before Nagoya:
and this one was spotted in the Xiv Eksiv Toba Annex Resort (Hotel) carpark:
Not much else to report in the way of Stagea's, but have had the pleasure of seeing a very good number of Prince Skyline's, Hakosuka's and Z432's...
Edited by prince_skyline
Spotted king 35 on the m4 stretching his right leg this evening on the way home from work, just after the old toll gates area.
Also spotted a 34 with neo74# plates on the m4 just after the church street on ramp.
red c34 on silverwater rd heading south about 930pm it was dark and only just noticed it
m35 turning from devlin st to victoria rd about 945pm i think it was gold or silver couldent tell at night
i was in my partners honda crv and she said
"how do you notice the stageas in the dark but i dont notice i get my hair done in the light or my new handbag"
spotted a gold ARX stacey street bankstown yestrerday about 1pm, i was the one blocking traffic, some ass ran into me,, now i got frontend dammage :(
Ouch, that sucks... :(
Spotted and hung out with StageIan on Tuesday @ Zen Garage.
Spotted and hung out with Duncan and Bodella on Wednesday night @ Wholesale Suspension in Penrifffffff.
Spotted a black C34 at Tyres and More on Prospect Road Friday morning... again!
Spotted a black C34 (Different one?) just off Prospect Road Friday night. Looking at the rear wing I'd say it could be Ruby's old one?
who's the dipshit L-plater driving the green C34 in vic?
Learn how to drive properly buddy, your mum who sits with you is obviously no better to allow your stupidity. The two times ive spotted you youve ran 2-3 red lights, and cut off numerous drivers intentionally.
Sell the stagea, you're not worthy of it.
Sounds like it won't be long before he takes himself out of the equation with that kind of talent; hopefully without injuring anyone else.
C34 wreck coming up for sale soon in victoria??
I want the RH front guard. The 25G has rust in both fronts. I have a lh one already.:bunny:
Needs to be S1
Edited by 66yostagea
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
