you know mad max?!?
lol... first thing that came into my mind too.
Lol, I thought his was black?
Yeah man, we go waaay back; I helped him build the church in his backyard, but we mostly just get blind & abuse female coppers. Good times...
Idiots.
Edited by Daleo
yellow dayz rs4S parked at the sexton hill (sth tweed) bypass roadworks,seemed to be at a glance as i drove by a s2 rear with definitly a s1 front :unsure: .....weird rs4s s1...no such thing is there??
Spotted a Gold M35 ARX today in Chatswood, about 145pm Had a huge dent in the LHS rear quarter that someone beat out with a hammer.
I think I remember one having a motorcyclist crash into it, was it this one?
I've spotted that one there as well Leigh. I gather he's working at the site. I don't know enough about C34's to pick up what it was exactly, but looked nice.
i think he's one of those guys who likes the s1 front over the s2 :rolleyes: and stuck s1 lights in cause the back end was s2 dayz
(NSW) yellow c34 at Minto - jango was driving the car
That was I.... He did say you knows you but had to have a second looks..we'll out for a test drive for bump steer I'm having ..30 seconds later the police are following us was so it was a short test drive
He did say another Volvo coming up behind hehehe
Nice Ride
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
