you know mad max?!?
lol... first thing that came into my mind too.
Lol, I thought his was black?
Yeah man, we go waaay back; I helped him build the church in his backyard, but we mostly just get blind & abuse female coppers. Good times...
Idiots.
Edited by Daleo
yellow dayz rs4S parked at the sexton hill (sth tweed) bypass roadworks,seemed to be at a glance as i drove by a s2 rear with definitly a s1 front :unsure: .....weird rs4s s1...no such thing is there??
Spotted a Gold M35 ARX today in Chatswood, about 145pm Had a huge dent in the LHS rear quarter that someone beat out with a hammer.
I think I remember one having a motorcyclist crash into it, was it this one?
I've spotted that one there as well Leigh. I gather he's working at the site. I don't know enough about C34's to pick up what it was exactly, but looked nice.
i think he's one of those guys who likes the s1 front over the s2 :rolleyes: and stuck s1 lights in cause the back end was s2 dayz
(NSW) yellow c34 at Minto - jango was driving the car
That was I.... He did say you knows you but had to have a second looks..we'll out for a test drive for bump steer I'm having ..30 seconds later the police are following us was so it was a short test drive
He did say another Volvo coming up behind hehehe
Nice Ride
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
