you know mad max?!?
lol... first thing that came into my mind too.
Lol, I thought his was black?
Yeah man, we go waaay back; I helped him build the church in his backyard, but we mostly just get blind & abuse female coppers. Good times...
Idiots.
Edited by Daleo
yellow dayz rs4S parked at the sexton hill (sth tweed) bypass roadworks,seemed to be at a glance as i drove by a s2 rear with definitly a s1 front :unsure: .....weird rs4s s1...no such thing is there??
Spotted a Gold M35 ARX today in Chatswood, about 145pm Had a huge dent in the LHS rear quarter that someone beat out with a hammer.
I think I remember one having a motorcyclist crash into it, was it this one?
I've spotted that one there as well Leigh. I gather he's working at the site. I don't know enough about C34's to pick up what it was exactly, but looked nice.
i think he's one of those guys who likes the s1 front over the s2 :rolleyes: and stuck s1 lights in cause the back end was s2 dayz
(NSW) yellow c34 at Minto - jango was driving the car
That was I.... He did say you knows you but had to have a second looks..we'll out for a test drive for bump steer I'm having ..30 seconds later the police are following us was so it was a short test drive
He did say another Volvo coming up behind hehehe
Nice Ride
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
