White C34 on Castlereagh Rd near Cranebrook Rd Penrith NSW going towards Richmond this morning around 8:50am. I was going the other way, waved but no response from male driver. His female passenger must have been a honey to ignore a fellow stage-ian. :rolleyes:
Spotted a silver Stagea (think the last numbers on his plate were AAY) near Bridge Road (Adelaide) yesterday, waved and tried to catch him but he was too quick lol, i've seen him a few times now, next time you see a short girl behind the wheel of a white 25T RS4 you could always wave back :whistling:
Here's a (hopefully non sleazy) wave from QLD ! :action-smiley-069: Female Stagea owner, that's awesome. Big up.
:action-smiley-069: hello right back at ya! i dont know many girls that actually like performance cars...sad really lol. I even had to get my stagea seat rails moved forward 2 inches so i could get my clutch in all the way :whistling:
It is sad ! Last time I found a girl that liked performance cars, I married her ! She's a small one too. No wonder she likes Holden Gemini's.
I'm 6'4", and honeslty could do with the seat rails 1" - 2" further back. Rear seat passengers would have to be amputated from the knee down though :)
If you feel like it, put up some pics of your Stagea in here http://www.skylinesa.../page__st__1780
Cya :)
QLD - Spotted a stock white S2 going south on highway near Tallebudgera @ around 4:30pm today. I :action-smiley-069: but got deeee-nied.
on Cowarra st taren point i saw a Silver PNM35 at a fiberglass place and then while i was watching it a White C34 drove past then of course there was my Black m35, i personally have never seen more stags in one place at one time.
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
