Spotted the left rear corner of Rosella's Stag as he tooted while I was filling up at Blaxland Shell servo tonight! :action-smiley-069:
Hey Dale, not sure whether you knew it was me!!!! Pity the poor bloke next to me though, he thought I was abusing him :whoops:
Just spotted a white s2 C34 on Blacktown Rd right where St Martins Village shops are, I was in my old man's car.
that would of been my wife pikn up my dinner.lol..
Must have been you driving, Josh - there was a guy in the driver's seat. I was driving a darkish grey Audi.
Bloody hope it was .lol..wish u were in a stag.id b on the horn waving like a crazy man.very rarely see a stagea in blacktown with a GUY driving.seen a few with women driving tho.looking at me thinking thrs cops ahead wen i flash my lights
