Well the major rust spot to look out for are around the front suspension towers,under the passenger and drivers mirrors,on the inside of the doors along the bottom edge,in and around the fuel neck/filler and around the boot seal. I also like to stick my head underneath the car to see if it has any major scrapes on the under the body or crash damage ie clamp marks on the seal panels,bent front reo ,creases in the skirts. Also lift the spair wheel cover up have a look at the beaver panel make sure the sealer looks original or it could also be a sign of crash damage. 1 last thing have a look inside the engine (take of the oil cap) and see if its clean or really black and dirty this will give u an indicator if the engin has been serviced regally or not also checking the dip stick for oil burn does the same sort of thing good luck with the Purchase
many many thanks to R33huntme
no worries something else to look at, the wear on the steering wheel Especially on the right side were u hang on and dents/wear marks on the drivers floor/Matt it's a tell tail sign of the kms the more were and tear the more kms it should have (u never can tell if the kms have been played with at least this will help
White C34 sitting on Main Street, Greensborough waiting to turn right up St Helena Road yesterday around midday.
I was in the yellow Stag which turned out of St Helena and went up Diamond Creek Road.
Another white stag, different to the one yesterday I think (the one yesterday had roof racks).
This time I passed it on the Greensborough Highway near the Civic Drive roundabout. I gave a toot and thumbs up on the way past (was on the red/white R1).
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
