Thats pretty much it, if you have bad luck and get done for defects, its tricky to get out of it with your mortgage intact.
Ive always lived here, when you dont have to pass the car every year, it gets more modified.
Ive had vehicles registered that go 260kph but so crap the exhaust falls off, its weird putting z rated tires on a shitbox.
However being a tradie i drive a ute every day(more mods) and dont seem to attract their attention.
Troy if your totally legal and everything engineered, thats hard to get, be proud. And enjoy peace of mind.
by the way 2 anchor points? did you get twins? that would be cool. :thumbsup:
haha yeah 2 anchor points. He did it so 'by the book' that he checks the vehicle plate to see if it's a 4 seater (2 points) or a 5 seater (3 points).
That's exactly it too, it will be entirely engineered except for when I put my exhaust ant BOV back on, which have never given me troubles anyway. Other than those 2 things, nothing about how the car sits right now is defectable.
Goodbye old faithful.
The ute is sold, had her for about 10 years, many great memories, like drifting on the dirt, in the dark, snowing, all the way to Adaminaby.
And hauling the bikes up to the brindies on those crisp, clear winter mornings.
However all the proceeds are going into the Skyline.
So funds to get ready for SAU nats in november.
Cosmetics or mechanicals... hmm.
Alrighty. Booked into Dickson tomorrow for what SHOULD be the final inspection. Everything they failed me on for this current roadworthy has been rectified, so logic says I have nothing at all to worry about as it will pass.
THE SUSPENSE IS KILLING ME!
Fingers crossed for ya Troy, dicksons new thing is getting a different inspector the second or third time around and they deside to look for more that was missed on intial inspection to out do the other inspector and big note themselves, kind of a "so and so missed this and this, I have to do his job because he can't do it properly". Happened to 2 mates in the last few months.
f**king hell. I'll near on kill someone if this happens.
EDIT: actually come to think of it, they did do this in a way...the second time I went through there wasn't on the same roadworthy, but I had fixed everything they failed the first time....however this time they picked up on the rear window tint, hole in boot floor and child restraints.
Shouldn't they ONLY check that I fixed the things I was previously failed for? Or is that too logical? lol
There's only 2 more things that I can possibly fathom they can still fail me on, one of which they were trying to determine last time but couldn't see it well enough to conclusively pick on it.
So how much has it cost you all up to get your car engineered?
Well it's hard to put a figure on it precisely...So we'll go with somewhere over $2500 inclusive of fabricating and fitting child restraints.
So without the child restraints it is considerably less.
What mods did you get engineered? Turbo, coilovers, wheels, fmic come to mind but was there much else they had to do?
Well the report covers the whole car - ie you can't ask him to engineer your coilovers while ignoring an engine swap or something. The report itself came in at $1350 ish, though a small part of this is due to having to fix a few things up then pay for reassessment of said things.
The scope of modifications covered in my ORIGINAL report are coilovers, rear camber arms, rear traction rod, HICAS lock bar, non-standard wheels, steering wheel (lol), brake lines, and turbo. There's also sundry additions like FMIC, dash gauges, pod filter inside cold air box, and oil catch can.
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
