Fingers crossed for ya Troy, dicksons new thing is getting a different inspector the second or third time around and they deside to look for more that was missed on intial inspection to out do the other inspector and big note themselves, kind of a "so and so missed this and this, I have to do his job because he can't do it properly". Happened to 2 mates in the last few months.
if its a reinspection within the 30 days of the initial inspection they can not add more to the list, only check what was failed before, outside of that 30 days you are free game.
This is interesting I guess Troy can shed light on how he got done 2x?
Incorrect, they have a "do what I want and get away with it" stamp, I've done inspections and let stuff like tint slide by 2% and the car has then gone to Dickson for an ID check and they have crossed over my pass stamp and failed the car and edited my inspection slip and failed for tint and headlight aim... When it was just there for an "ID check".....
I have here the first ever commercially avaliable "Clapper" light switch! :D
Patent Pending.
It simply replaces an existing light switch so you can clap the lights on and off from the comfort of the couch! I've got a batch of 10 ready to solder up.
Richard. I'm off to the coast on sunday, but I'll have 2 ready for you if you want to pick them up tomorrow (saturday)?
Good question Zebdrew, maybe when the sun and warmth comes back out to play.
Yeah that's a good point lol
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
