Is it just me, or is it cold tonight?
Yes
Combo of the 2 Duncan. ;)
I haven't seen this Game of Thrones but I have heard it's pretty full on...
Would you guys say it is inappropriate for a 15 year old Girl to watch?
I only ask as my Niece watches it with her Father and from what I've heard, I don't think I would allow it.
f**k no
it wouldnt let my parents watch it haha
If it's ok to see graphic scenes of peoples throats/bodies being slashed open, heads cut off, horses heads cut off, sex scenes that almost show everything..... etcetc. There was even a penis in the last ep I watched!
But in general, everything bad you can do with a sword, axe, olden times weapon... they do it :yucky:
So who is entering the next hillclimb?
I am....in the barge
Duncan...you best be there!
I'll certainly come n watch.
the Queen, who had incidently just eaten a pumping, raw, sexy horses penis to prove herself. Yep, it's that kinda show.
Lol. I think I'll just stick to Top Gear and Big Bang then...
haha has harry inspired you? I think an auto would be very frustrating.
BTW anyone thinking about it, a hillclimb is about as cheap and simple to enter as motorsport can be. it is unfortunately a little more risky than a race track because the trees don't stand back very far.... kel almost shit herself when the brand new z left the track at SDMA sideways (look on her face afterwards was priceless)
no definitely not. in fact almost no motorsport events do which makes the SAU NSW days a great thing.
but ultimately it's just a more raw experience. you can choose whether to go slow enough to be totally safe or fast enough to be dangerous...it's nice to have choices.
Anyone not watching GoT is missing out. It has everything! We even got my parents onto it and they love it!
No passengers .
Ive never seen a big stack at sdma
Just be sensible and youll be fine.
Ye dunc frustrating but better than nothing
Oh so you weren't there when Lora rolled the Micra!
Entered :banana:
4 weeks is too long to wait, so ill have to do some more mods/adjustments in the meantime.
the other guys in class 3 were getting 50 sec, i got down to 54.66 on my first day,
i think i can get close to those V8s if i can get a little more traction, and drive better.
Im sure the car is capable of it, the main problem is the driver. Actually im surprised my shtter did so well.
But id like to do it on the same tyres, they all have semis and id like to save mine for later.
    • Next, remove the upper and lower radiator hoses, both are held with a spring clamp. While you are under there, tackle the Auto Trans cooler lines.  Again both are held on with spring clamps, and as mentioned above you should cap them on the radiator side with an 8mm cap, and on the car side loop them with a length of 8mm pipe - this will stop you losing a dangerous amount of AT fluid during the rest of the job If you've been meaning to add a sender for AT trans temp, this is a great time to do it; put a sender fitting into the passenger side line as that is the inlet to the cooler/radiator.
    • Next you need to remove the intake duct (as with pretty much every job on these cars), it is a series of clips you gently remove with a flat bladed screwdriver. They do get brittle with time and can break, and I have not found a decent quality aftermarket one that fits (they are all too soft or flimsy and don't last either) but the nissan ones are a couple of bucks each (ouch).  Once the clips are off (either 8 or 10, I didn't check) you lift the intake duct out and will see the reservoirs Undo the line into the radiator side cap (some bent needle nosed piers are awesome for spring clamps) and then remove the 4x 10m nuts that hold both in place.  I didn't get these pics, but remove the line under the radiator reservoir (spring clamp again) then remove that reservoir. Then you can get at the intake reservoir, same thing, spring clamp underneath then remove it. BTW This is a great time to put in a larger (+70%) combined reservoir that AMS makes..... https://www.amsperformance.com/product/q50-q60-red-alpha-coolant-expansion-tank/ They also make an Infiniti branded and part# version if that is your thing
    • To drain the Intake Heat Exchanger, there is a crappy drain plug in front of the driver's side front tyre: You should use the largest headed phillips screwdriver you had, and in my case I needed vice grips on the hose above as the plug was tight (tighter than it needed to be, since it has an o-ring seal).  After you have a tray down and open the drain, open the intake heat exchanger reservoir cap (drivers side one) and you should get a couple of litres of coolant To get to the radiator, you need to remove the plastic engine undertray. It is held on with a series of 10mm headed bolts and some clips. For the radiator, there is another type of crappy drain (kind of like a plastic banjo bolt) and you should attach a length of hose to direct the stream of coolant per this pic (otherwise the coolant hits the rad support and goes everywhere). The drain is on the rear of the radiator on the driver's side and a bit hard to find. Put a big tray or bucket down (5l won't be enough) and slowly unscrew the fitting by hand. You only want to remove it far enough for coolant to flow, it you unscrew it right out the whole fitting and direction pipe will come off and you will get a coolant bath (yum!). Undo the radiator reservoir cap and it should empty about 8l
    • So, this shouldn't be such a mission, but there were a few tricks so I thought I'd post up a DIY for it. This was on a Q50 Red Sport but I doubt any other V37 model is very different (maybe just less steps for the intake heat exchanger hoses) I pulled the radiator out to flush it because the car was running hot at the track, but obviously the same steps apply for changing a radiator for any reason including an upgrade. If you are removing the radiator, you of course need to drain and refill, so have 5+ litres of blue coolant ready. You also need to drain the intake heat exchanger to remove the radiator so you will need a couple of litres for that as well. You will also need something to deal with the auto transmission lines, I used 2x 8mm rubber caps on the radiator side, and a short length of 8mm pipe on the car side.....unless you can block these lines quickly you will loose AT fluid and it may be enough to hurt the transmission if you don't refill it. 2 other tools that really help dealing with coolant lines and spring clamps are Bent Needle Nose pliers Hose pliers Between them they will reduce the frustration (and injury) potential by about 1000% Other than that....lets go... "First, jack up your car". Yes really, and put it safely on stands. If you are not confident doing that you need to give this job to a mechanic
    • If the forester is anything like our old 2007 GTB Liberty, I could near on run ling Long's and "rate them", as no matter what, it just hung to the road, even when abusing it in a hard launch in the wet, or throwing it at corners.
