I will be going on Saturday morning
Ticket is $70 :(
Also who is good with clutch.
I did my clutch and its making a very loud noise when i release the pedal its vibrates very badly makes the whole car shake also when the car is in gear i can spin the rear wheel with hand.
The pressure plate that i put in which came with the new clutch kit is a little small, will this be the problem.
Edited by 5hiv
  • Like 1
Just moved it in my garage not driving it anywhere mate.
Im so pissed off because i did it on the floor and it took me ages especially the gear box take a lot of time
See thats what i was worries about getting a wrong parts if i bought it myself so i just bought the whole kit from trojan he ordered everything for me
Hopefully he is going to be open tomorrow
If John bought it then it will suit the vehicle
Doing a clutch the first time and doing on the garage floor is definitely a painful process
Expense is in the cost of the clutch, not the install. IMHO it's best to get it installed too
(That way there is no argument if it's clutch components or install that's the issue if things go wrong,)
Edit: You bled the clutch cylinder properly?
Edited by Sinista32
Gotta love days off! Might get the nitro rc back out today. Hasn't been run for 6 months or so because it was too cold. Mmmm.. Sweet sweet nitro :happy:
Ahh I wish ! I fried the engine in mine. No compression. Didn't tune it after the run in process. It's bean dead for about a year :(. I do love the smell of nitro :D
Woops, yeah my engine seems fairly strong. Needs a real good alignment though haha. Pulls right fairly hard even with left trim :S
Ticket is $70 :(
did you machine the flywwheel? was it torqued up correctly?
Pressure plate needs a very long process of torqing up in the right pattern.
was everything totally clean, real clean?
Just enough of the right grease in just the right spots?
I did all this first, and still it wasnt easy.
The clutch fork can pop off and jam as your putting the box back on. Did it to me about 4 times before i got it.
My gearbox was on and off a few times before i got everything together right. What a pain.
RB20 box was heavy enough for me, yours must be heavier.
You guys have on or off road cars?
Mines a road car. I sometimes wish it was off road though so I could take it anywhere
But you cant, its gotta be just right.
It can be a real pain finding a good spot for on or off road.
My Tmaxx got taken out by a brick at a building site. Full boar second gear, didnt see it till it was too late. >_<
After that i never went back to nitro
85 amps from a lipo got me hooked on them and brushless motors.
Instant full power, more than nitro, its nuts. So easy to build a car thats way too fast.
Edited by D.I.Y. Mik
  • Like 1
I've got both. :D
and yes I've spent many a time searching thru rocks, sticks, leaves and dirt trying to find that screw that parted ways from my RC and ruined my fun. :/
Sir Son of Rajab Van Von Vader'ham. :laugh: Pricless.
    • Plazmaman 76mm Pro Series, done. Data to back it up, I posted up somewhere here a few years back
    • So.....wire it up appropriately. You can't use the resister pack with those injectors anyway.
    • that’s the thing i’m on ID1050s and haltech not getting power due to the injector resistor
    • ahh okay cheers, i was thinking of just going for the m073, think m079 would be way too overkill considering they are same size.
    • My first car was a HG. I'm very familiar with them. A mild cam upgrade is a good idea. The 186 is a very flexible engine - meaning it has good torque from down low. You can give up a little torque down low for quite a lot more excitement in the mid range, and a bit more up top - but they are not exactly a rev monster. You need to upgrade valve springs at the minimum. For a bigger cam, you'd want to make sure it wasn't still running the original fibre cam gear. That would be unlikely, given that most of them shat themselves in the 70s and 80s, but still within the realms of possibility. Metal cam gear required. Carbies are a huge issue. The classic upgrade was always a Holley 350, which works, but is usually pretty bad for fuel consumption. The 186S had a 2 barrel Stromberg on it that was very similar to the one on the 253, and is a reasonable thing if you can find one, and find someone to help you get it set up (which is the same issue with setting up a 350 to work nice). The more classic upgrade was twin sidedraught CD type carbs, or triples of same, or triple Webers. The XU-1 triple Webers being the best example. You can still buy all this stuff new, I think, but it's a lot of coin to drop. And then the people able to set them up are getting fewer and further in between. There's still some, but it used to be everyone's** dad and uncle could do it. **Not everyone's! But a lot. All in all, I wouldn't get too carried away with the engine. Anything you do to it without a full rebuild for power and revs will only make it slightly faster. I am all in favour of a complete teardown rebuild, with nice rods and pistons, 10 or 10.5:1 compression, and a clean port job with at least a big enough cam to run 98 with that compression, if not bigger. And if I did that to a dirty old red motor, I'd want to inject it too, which I'd struggle to fight against the devil on my shoulder that would argue for ITBs and trumpets. But the bills would start to mount up, and it will still never make stupid power. OK, a few people still know how to build absolutely mental red motors, courtesy of the work that went into HQ racing and modern knowledge being applied. But even a 300HP red motor is no match for an RB20 with a TD06. So you have to decide what it's worth to you. I'd just put a set of 6>2>1 extractors, a 2.5" exhaust and an electronic ignition conversion/dizzy on it and just run the old girl like the fairly slow old girl that she really is.
