Im thinking then the only annoying bit would be if its got coolant lines, then you have to drain the coolant.
Oh and some of those bolts holding it together would be tricky to access.
I have ratchet spanners and stuff to get to annoying bolts if you need.
i found a good trick is polish it real good, spray with good clear bonding agent paint, then gloss clear over that.
Polished forever.
Blacken that lip. :mrt:
Thinking of lippage for the Wagon too, maybe a Foamy one like Chris's or perhaps something else.
Tried one of the Kebabs from Charnie just now. Jeremy, I now know why you get them. MMMmmm mmmmm... :P
yea, they shop up the road sells them! I can barely finish one :/ they are huge
Foam lip? that sounds like a good idea.
Light, soft and able to resist lots of air pressure.
Mint snowfoam lance turned up today, watching the weather so i can do a wash and try it out. Might have a go at polishing and everything.
Also found that Masters hardware Workzone brand pressure washers are the same fitting as Bosch.
The doofus at the hardware counter said " The Bosch rep said not to use other brand products with the pressure washer, we dont have any parts, we just got them for christmas."
The hose fits perfectly, its exactly the same fitting. Thanks to ignoring the idiot staff i got the right hose.
So now i have 11m pressure hose and good accessories.
:santa:
Yarralumla kebabs FTW. By far the best ones I have ever had
Charnwood The land of goat sphincter rings kebabs are pretty insane. It's probably the only thing Charnwood could "claim'. :(
Yah! as stated, the Kebabs are Very Good. Big, Filling and well worth the price. Might try their Pides too.
Charnie also has : A Very Good Dentist, The Takeaway does Very Nice Pizzas, Burgers, Steak Sambos, Scallops etc... makin' me hungry.
The Chinese is also Tops.
and the Woolies chick that Loves Skylines. :D
  • Like 1
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
