Yarralumla kebabs FTW. By far the best ones I have ever had
I haven't had one for about a month. Think I might get one for lunch tomorrow ! Yarralumla kebabs are by far the best out there ! But everyone I'm yarralumla calls the cops the second they hear a loud exhaust. Yet to be pulled up on it tho!
everyone in yarralumla calls the cops the second they hear a loud exhaust. Yet to be pulled up on it tho!
No offence to you or your family, but 90% of the people in Yarralumla are d!cks, old or yuppy snobby d!cks.
These are the type of people that stopped GMC/fire crackers etc, ugh I can feel my blood pressure rising lol
Edited by gtr judd
  • Like 1
Charnwood The land of goat sphincter rings kebabs are pretty insane. It's probably the only thing Charnwood could "claim'. :(
I will indeed have to try one...
Yah! as stated, the Kebabs are Very Good. Big, Filling and well worth the price. Might try their Pides too.
Charnie also has : A Very Good Dentist, The Takeaway does Very Nice Pizzas, Burgers, Steak Sambos, Scallops etc... makin' me hungry.
The Chinese is also Tops.
and the Woolies chick that Loves Skylines. :D
I will agree on all these + it has two grog shops, the chemist, the newsagents (that save me traveling to Belco for parcel collection), maccas, shell v-power.....
It definitely has a well equipped little shopping area
Edited by gtr judd
I want to try one now too.. Shame it's so far away :/
Shoot me an address and I shall venture to the other side of the world one day soon :)
The best I've had was in Melbourne. Was insane. The Charnwood kebabs have real The land of goat sphincter rings bread. They're big ! I struggle to finish one most the time, and this is me we're talking about ! Hot sauce + sour cream please. !
A kebab cruise sounds good :P
2 minute cruise for me if that's the case Judd :P haha
Haha yeaaa. Its mainly so we can show those southsiders how green the grass really is, however we could organize a decent cruise and end up with kebabs and drinks at mine, then a few too many drinks and sleep on my lounge/floor and go for more kebabs for breakfast.
Alcohol + Kebabs = Better love story then twighlight
  • Like 1
That actually sounds greeaaat :woot:
  • Like 1
I hate to even briefly interrupt some good kebab chat, I just thought I'd put this here as my employer is looking for a new sales rep to cover the ACT & NSW Riverina area. Great opportunity for anyone who is interested in an entry level sales role with a global business.
http://www.mars.com/global/careers/job-search/job-details.aspx?JobReferenceNo=NEW00703&SelectedLanguageID=2&CareerSite=10300
^^^^^ I've been very tempted to interrupt mate, so I'm glad you did, it has probably saved me from a fate worse that death!! i.e. condemnation by the ACT Wasteland, I sincerely thank you. :yes:
Edited by THE34T
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
