What was it again?
Sexting...
Whats that?, is that a crime? I guess its like porn, so underage isnt allowed.
I dont really understand it, but it just sounds like the modern equivalent of trying to hook up with a girl in very bad taste; or not being able to hang with your girl, so you do that.
Id say it must have been fairly inapropriate (cant spell) or it wouldnt have been such a big deal.
What was it again?
Sexting...
Yeah I think it was that. A lot more common than you think.
Anyone have any good/bad experiences hiring car trailers locally?
I hired one from the BP petrol station in Phillip on Melrose drive.
It was roughly $150 for the day I believe and it worked fine for picking up my Mazda from Braidwood.
Trailer wasn't an old rusty one either.
Worked out a bit too hard given the braking requirements etc and what's around in the ACT.
Going to need it a bit over the next few months so ended up ordering one that we'll have in time for when I head out next. Trailer queen life begins!
26th of July is when I'm back for good. Flying to Sydney next weekend for two night just to catch up with family.
Caught up with a few of like minded people over here and went for a cruise in a 34 GTR. Hopefully there are a few more meets here to fill that void of not having a car haha.
  • Like 1
I noticed today that both my Drivers side NISSAN valve caps on the SkyWaggot are gone.
I can't help thinking that 1 of the 3 little Turds who rode past my house today has them on his bike. :verymad:
They only cost me $6 or so on Ebay but still, I bought them cause I wanted them.
Thieving Pricks.
If I see my valve caps on a pushy at the Charnie shops, Excrement will impact with the Turbine.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
    • Run some injector cleaner through it I had a similar issue that plagued me for months, even tried replacing the cat. If one or more injectors are blocked up the ecu sees ping so pulls timing and makes the tune rich overall, you'll see black smoke coming out of the exhaust and like me assume it's running rich but it could only be one or two cylinders  $10 bottle of injector cleaner and the next time I hit boost it pumped out a huge plume of black smoke, cleared the blockage and then ran great, if that's not the issue it's only a cheap thing to try haha
