R34 RB25 Neo
FMIC
Oil Cooler
Engine Earthing
Pod Filter
Blitz DSBC
Type 3 BOV
Apexi AX75F82 turbo
Stainless steel exhaust manifold
3" turbo back exhaust
Z32 Afm
480cc Injectors
Bigger Fuel Pump - Unknown
Apexi PFC
100 Octane
261.3rwkw - 1bar(14.7psi) - 350rwhp
243rwkw - 0.8bar(11.5psi) - 327rwhp
234rwkw - 0.6bar(8psi) - 313.7rwhp
Hi all, just got everything done and dyno tuned on my car. Here it is:
R33 GTS-T (RB-25)
Mods:
HKS GT2835 Pro S 0.68 A/R Turbo
GReddy Front Mount intercooler
Nismo 555cc Injectors
Bosch 040 Fuel Pump
3.5 inch straight through exhaust with split dump
Power FC
Z32 AFM
Cold air intake with pod filter and heatshield
Splitfire coilpacks
Platinum spark plugs
272.3 RWKW at 18 PSI
Edited by Turbz RB-25
R34 GT-T (NEO) '98 Manual
Stock Turbo
Greddy FMIC
Greddy Profec B EBC
Walbro Fuel Pump
Nismo 480CC Injectors
Greddy E-manage Ultimate
Z32 AFM
3 inch AM performance front/dump, high flow cat, 3 inch zaust.
Apexi Intake
208.3kw @ wheels on 12 psi on a 40 degree day.
Stock Turbo
Greddy Profec B Spec II (11psi)
Metal cat & HKS Cat back exhaust (No Dump pipe yet)
K&N Pod Filter
184.1 KW @ Rear Wheels - 11 psi
175.4 KW @ Rear Wheels - 7-8 psi (Stock Boost)
Edited by R33Turbo
R33 GTST S2
Stock internals/unopened
Power FC
HKS GTRS turbo
Blitz LM FMIC
3.5" turbo back exhaust, Metalcat convertor
Solid piping mod AFM > turbo (rev210's intake mod)
550cc Nismo injectors
Nismo fuel pump
Z32 AFM
Stock BOV modded to suit
STOCK AIRBOX
256rwkw on 16.5 PSI (High boost)
241rwkw on 12.5 PSI (Low boost)
The dyno chart maximum was from a run with a modified airbox, but only got 3kw extra, so no point. Line below that is how it stands. The lower line is on low boost.
Edited by sl33py
1995 R33 GTS-T Series 2
Apexi Power FC
GCG High Flow Turbo
TurboTech Manual Boost Controller <-- so good
FMIC
Apexi Panal Filter inside stock airbox
Stock AFM
Stock Injectors
Walbro 500hp fuel pump
3" Turbo Back Xforce Exhaust Stainless Steel
Stock Internals
Manual
221.5rwkw @ 15psi (300rwhp)
car has air and exhaust restriction somewhere will be fixed and retuned looking for 240rwkws...
R33 skyline RB25DET
Garrett GT3076R
Apexi Power FC
Z32 Afm
FMIC
Tomei Fuel pump
Greddy profec b spec 2
Apexi power intake
HKS super drager exhaust turbo back
Made 233 rwkw which is 310 rwhp on 17 psi full boost by 3800 rpm. Was aiming for 250 rwkw though not sure what went wrong.
Edited by SexyPete
This was a quick touch up tune for Texi after running in the engine.... proper tune with more boost in 2 weeks - stay tuned!!
R33 S1 Skyline
Garrett GT35R - 0.63 rear externally gated (0.82 on standby, just want to max this rear out first )
6boost manifold
38mm turbosmart ultragate (needs to be upgraded if keeping the smaller rear housing on)
3" exhaust with metalcat - proper mufflers, no cannons....lol
Greddy E-01 boost controller
550cc injectors (740cc nismo's on standby)
Haltech E11V2 - wideband 02 and display also installed
greddy intake
rebuilt engine - forged internals 20thou oversize - 4,000 odd kms old - Rebuilt by Dave aka T04GTR *shameless plug :laugh:
Some little tricks done to the head - wouldn't tell me :(
Step 1 poncams
FMIC
Walbro 255 (044 being installed prior to final tune)
Sard FPR
94 r33 gtst
Engine
Standard internals
gt3076r 0.63 rear - high boost is 300kw @18psi :D
low boost is 250kw @ 13.5psi
on a chassis dynapack dyno (low humidity, 22 degree day)
greddy profec B electronic boost controller
standard injectors, running at 75% duty cycle
sard fuel reg
bosch 044 fuel pump
z32 afm
splitfire coilpacks
haltech e11v2
hybrid front mount intercooler
apexi pod filter in custom box
maganflow 3 inch turbo back exhaust, with high flow cat and hi-tech resonator
car is a bit laggy, but incredibly fun once it gets going. probably get some cams in the future
bit late.....got my setup mildy tuned about 2mths ago by matty spry. LEGEND.
garrett 3540
z32
3'' zorst.
pfc
and secret parts :D
exedy carbon-d twin plate clutch with lightened ventilated billet flywheel
got me 385.8hp
not game to go higher without pistons. prefer to have it safe and thrash it. than to have 400+hp and break it when i floor it for the 1st time.
Edited by r33cruiser
With so many threads about turbo upgrades for RB25's i thought itd be a good idea to start a thread that shows results only, as the results from various threads are scattered everywhere. Everyone has there own ideas about what power they want so obviously there isnt ONE perfect turbo upgrade for everyone.
Please post your RB25 dyno graphs only and state the following:
-Engine management
-Boost ran
-Fuel used (pump or special)
-significant engine mods (eg cams)
The idea of this thread is to be a quick reference to various turbo's performances on RB25's, not to be a discussion thread.
Thanks
(If this has been done already let me know, but didnt come up one in search.)
1993 R33 GTST s1
Power FC
Z32
Stock 370cc injectors
Stock internals
GT3071 Internal gate @15psi Boost (comes on at the same rpm as stock turbo!!!)
Bosch 044
Splitfire Coilpacks
Greddy Type M FMIC
Bp Ultimate
X Force 3 inch turbo back
Profec B (turbo wastegate is 15psi so couldnt use teh Boost controller as the injectors were maxed out)
235.4kW Atw
R33 GTSt 93 model
Apexi pod & box
z32 AFM
slide hi-flow turbo
FMIC
Nismo 555cc injectors
Greddy Profec II boost controller
Apexi powerFC
3 inch front and dump pipe
3 inch hi-flow cat
3 inch Nismo cat back
235.8rwkw @ 15psi - all work done by Unigroup :)
cough upgraded copugh :)
Same mods minus the blown hi-flow.....
now with GT-RS fitted and tuned, again, by Unigroup :D
187.9kw @ 6700rpm
1996 R33 Skyline GTS25t
600x300x76 FMIC (China)
JustJap Racing Split Front/Dump
JustJap Racing De-Cat Pipe
Full 3.5" TRUST Cat Back
Manual Boost Controller @ 10PSI
Pod Filter
SAFC Neo
Was hoping for a little closer to 200kwkw, but the Neo is a pretty rough tool, so hopefully a Power FC will see that goal come a little closer.
RB25DET S2 R33 Skyline
Standard Turbo/injectors/ Fuel pump
Blitz FMIC
K&N Panel Filter
3 inch dump Hi flow Cat
Kakimoto cat back
Gizzmo EBC @10.5psi
Power FC
201.1rwkw
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
