  • 5 months later...
everyone is going about removing the HICAS what is the main benefit of removing it maybe a noob question but ive read the 300ZX sites and some of the people on there like it and they have reached the 20yr old mark.
Edited by B-rice
  • 3 weeks later...
hi, am in the middle of removing the hicas unit behind the diff, how exactly do u " crackoff" the rod ends which connect to the unit. thanks
exactly my thoughts, how to do this??
have you done yours?
breaker bar with these kinda tool attached? (http://imgur.com/sUJ7i)
  • 2 months later...
I hate to revive an old thread, but I will be fitting a HICAS lock bar to my S1 R33 GTST.
The instructions on page 1 seem a little outdated given the comments in the rest of the thread, alot of people are doing alot of different things about the power steering lines etc.
Has anybody done on a 33 recently, what did you do and were you happy with the outcome ?
Attempted this last night with not alot of success. I couldn't "crack" the 4 sided rod out of the HICAS unit . The HICAS bar I brought still has the arms in it , now I know why !
It's going to need persuasion of the vice kind I reckon ! . So I thought seeing my bar had arms already , that I would just remove the HICAS system as one whole unit .
Well that didn't happen because one of the nuts was rusted shut , it started to round off which is when I stopped . Put my HICAS back in , cracked a beer and called it a day .
Thinks I might just get a workshop to put it in and wheel align at the same time .
It seems what should have been a simple job ended up being a pain in my arse .
Can anybody in Adelaide recommend a workshop that is happy to put a HICAS lock bar in with wheel alignment without robbing me ?
  • 3 weeks later...
I just tried to remove mine and... i have a 3 and a half inch exhaust on my 34 GTR, so could not get the the right hand side, and could not crack off the arms -_- to a mechanic tomorrow to do it, dont have the tools i need to do it correctly fml
  • 2 months later...
has anyone here ever had issues with the arms coming loose after they have installed the HICAS lock bar?
I had my wheels aligned after installing coilovers and the car didnt feel right, but i couldnt figure out what it was. then i was driving it the other day and the rear rod that connects to the lock bar came out of the lock bar :/
had a look underneath the car for the first time today since and noticed the other side was loose as well. has anyone had this issue? i did them up bloody tight when i first installed it.
  • 2 months later...
  • 2 months later...
No. It might take a bit of load off the tie rod end when you're undoing it but it won't cause any dramas doing it jacked up.
However in saying that, most suspension components should be tightened up with the car sitting as close to normal ride height as possible (wheels/suspension carrying the load). It's more of an issue with rubber bushes as they will twist and bind up a bit if you fully tighten them before lowering the car onto the wheels. You should assemble the parts with the bolts loosely tightened then lower the car onto blocks under the wheels or put the jack stands under the rear arms so the suspension is bearing the load (this is done so you can still get under the car!) and then tighten everything up to the correct torque. Drop it down onto the ground and should be all good.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
