I've got internal hex [allen key] wheel nuts, I had the outside done properly, and the inside just overspray on chrome.
I used a 'tree' - made up of bolts welded onto a 1.5 metre strip of steel strap - with the wheel nuts screwed on to protect the thread. This way the blasters and powdercoaters only had to hang the tree up and do their thing. The outside was blasted and chrome removed, the thread was not touched, the internal hex was only blasted by overspray, not much chrome removed.
The same effect happened with the powdercoating.
powder coating wheels... wish i had thought of that sooner.
I have made a mess of my wheels, rubbed against concrete gutters, etc... so when you say you have to prep the wheels yourself, does that mean sorta filling them first where 'chunks' have been removed and sanding them back???
Can't use filler or nikky under powdercoating, the ovens melts/burns it.
Prep involves sanding out rough spots, taping up where you don't want it sandblasted, screwing bolts into thread holes, taping exposed thread on bolts.
Some powdercoaters will sandblast and powdercoat, others tell you to go and get it sandblasted yourself and then they will powdercoat.
Note that any taping you do [to protect polished areas or threads etc] will only last for the sandblasting, you have to have a special heatproof tape for the powdercoating. If you ask nicely the powdercoaters will usually give you a bit.
Powdercoating [for those that don't know] involved spraying an article with a dry plastic powder {using electrostatic properties -/+ connections etc, usually the spraygun is + and the article has a - lead attached to it}. The article is then hung in an oven, without being touched, and heated up and the plastic powder is melted on. This process will not cover up/fill blemishes/scratches in the article. They will be coated, but a scratch is still a scratch, just that now it is a powdercoated scratch.
I can't remember the oven heat, I think about 270' C, I do know it is hot enough to melt plain solder [soldering iron], but not silver solder [used with an oxy welder].
I have heard that powdercoating is quite difficult - have to get the temps right or else the finish will crack after time?
One of the Vic boys with a GTR has white powder coated 33 GTR rims that have cracked quite badly...
  • 2 months later...
ive just had mine done yesterday in thomostown...to powder coat them and sandblast em they charge $90 a wheel..
There called ADA powdercoating
number is 94653390
If you have the time, some pics would be great (particularly closeups to get an idea of the finish).
Cheers,
Lucien.
The company my mate works for, Form 2000 (near Moorabbin Airport), have a powder-coat line but I've never enquired about.
Maybe look them up and see what it's worth, when i speak to my mate next I'll ask him about it but he's a floor foreman so the pricing isn't really his department, just makes sure the work gets done.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
