in conclusion, they aren't that bad for your turbo as evidenced by the many workshops that do it to their cars, however, no skyline enthusiast with half a brain would do this to their car for fear of being mistaken for one of the stereotypical losers that actually do do this to their cars to make them sound 'fully sick' as that is purely not what driving a skyline is about.
my 2c
  • 2 months later...
  • Replies 300
Posted Images
BOVs are f*king gay, they sound like a gay c**t farting
a shit load of hi po rotors my mates have had didnt have any BOV and same with my mates other cars although most had massive garrett turbos
my new engine isnt going to run a BOV
IT DOESNT MATTER....
Compressor surge does jack crap to your turbo... it wont "blow it up", your turbo is working harder compressing the air than coming offboost.
Please get a timing light with any car running a high-mount on a dyno, and SEE what happens to the compressor blades when the "big bad cooler noise" happens... haha yeh man... the turbo blades stop/start spinning backwards.. haha.
FFS stop reading useless advertising crap off of the turbosmart F.A.Q
One of my best freinds (drives a straight gas VL turbo GAS-747) runs a 10.80 all day/daily driver, runs 30PSI driving over 2 years without ANY problems with the turbo at all. (GT40)
Look at most sub 10 sec turbo VLs... what a suprise... no re-circ B.O.V.
Really as posted above, its horse's for courses. Whatever you prefer, i have NEVER heard of a turbo destroying itself through compressor surge and if it was such a major issue for turbo reliability most TOP STREET drag cars would be running them. (Bres, rajab come to mind)
if your after turbo reliabilty, run a R34 NEO or GTR oil & water pump... that will save your turbo before a BOV. But whatever floats your boat mate! :D
Cheers,
Trev
i had a ssq bov on the car when i bought mine, and it must of been adjusted to tight, and the ssq sound i was hearing was flutter, but i was none the wiser as i thought it was the ssq, i only found out due to i bought a greddy type s (knock of) and put it on and it also was to tight and was still making the flutter, played around with it for a while and still can not get rid of the flutter, i got a high flow turbs but f_&* knows whats goin on, maybe cos they were both cheap knock ofs, the flutter has done no damage to my turbs though, ..oh well thats my rant
this coming from a man who has a BOV on his R32?
very amusing...
no.... the BOV was removed because its useless just gets cops attention and book your ass.
If you run a BOV just leave the standard one. But when you go serious power remove the BOV>!
I was under the impresion that no bov was louder than having one? Thus less attention for a factory fitted item. <_<
took it apart and it had 2 springs in it, i would say a high and low boost spring in it, kept the soft spring in it as only runnin 9psi and hopefully stops reversion,
This is correct. Plumback BOV's were fitted on skylines for emmission control...
I think they are alright. They're one of the reasons I like turbos...
My 2 bob.
I haven't looked in to it enough, but the way I see it when you've got compressor surge you're applying a force to the blades that it otherwise wasn't designed to take.
The force itself might not be as strong as when the turbo is on-boost, but the compressor wheel is designed to take load in that direction.
The air might flow a different way but the force is in the same direction.
My 2 bob.
How does fitting a BOV correct emissions? The standard skyline bov's simply recircluate back into the intake system. Without a bov the air is still in the same location. I don't see how it "helps emissions". The BOV is simply there to prevent compressor surge when the throttle body is closed
Well....
The air in the plumbing has to go somewhere right?
It goes back out of the turbo (surge) and into the atmosphere, passing the airflow meter on the way which read some airflow and the ecu pumps fuel through your injectors giving you a black puff of smoke.
If you have an atmo BOV, the turbo keeps sucking air and the air flow meter reads the air - etc.. see above for the rest.
A plumback keeps the air circulating through the plumbing,after the airflowmeter, the aflowmeter doesn't register any airflow and there is no polution.
You're going to have to unpack that for me, and explain how air flowing in a different way can also be applying force in the same direction as when its not flowing in this "different" way.
well the stock bov noise on my rb25 was pissing me off, so i made up a metal gasket blocked it off, and now my car flutters, i only run 10psi and so far no damge, and it dosnt really slow the turbo down at high revs when making boost
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
    • Run some injector cleaner through it I had a similar issue that plagued me for months, even tried replacing the cat. If one or more injectors are blocked up the ecu sees ping so pulls timing and makes the tune rich overall, you'll see black smoke coming out of the exhaust and like me assume it's running rich but it could only be one or two cylinders  $10 bottle of injector cleaner and the next time I hit boost it pumped out a huge plume of black smoke, cleared the blockage and then ran great, if that's not the issue it's only a cheap thing to try haha
