  • Replies 635
^^ You don't make sense.
Exactly what i said. R33 turbo models are not GTST,they are GTS25T. only R32 came GTST just the same as R34s only came GT-T.
Wankery technical i know but facts is facts.
well then people should refer to their cars as ECR33, BNR33, etc if you are going to get technical about abreviating models
Difference being there isnt ECR33 stamped on the rear end is there?
I know im bein a technical dildo but i like technical stuff.
But yeah a GTST is a GTS R32 Skyline with an RB20DET
And yeah ill admit i don't Prance around saying GTS25T all the time,but atleast i know the secret truth.. lol
On a side note: is the 34 a GT and not a GTS because of the fact its a different shape and design from the GTR as opposed to R32 and R33 being of the same sort of design?
There is not R34 GTS iirc
Yeah i was asking if anyone knew the reason for this.
badges dont mean shit vl have holden badges on the back
but they have a rb30 in em they dont have gts30t on the back do they
And we have a winner..
If ls1 engined commodores have chev badges, shouldn't rb30 vl's have nissan badges?
My hardcore commo loving friends did not like that question lol.
Do you REALLY want to see a Nissan badge on this?
Neither would I.
And Reading the argument about the GTS25T, I knew that that is the model of the car but when people ask "is it a GT or GTST", do you really want to reply "Neither, its a GTS25T"?
R34 only came out in the GT, GTT and GTR(vspec etc).
Neither would I.
VL Calais is a nice car but its not Nissan just like a holden is not a chev.
And if i want to be technical,yes i do want to say it lol.
And no one seems to have read my question right. i was asking if 34 is GT and not GTS because of the fact the GTR isn't essentially the same car with bigger guards. GTR 34 has shorter wheelbase as well.
Neither would I.
Bahahahahaha very true
Yes it is. The chev badge pisses me off for one reason only, and its that the owners wont admit its there purely because it looks nice, in fact a hell of a lot nicer badge design than holden. IF they really wanted to get picky about their badges and motors, hell they would have a gm badge on it, not a chev badge. That has the same significance as a pontiac badge, but the pontiac badge doesnt look good. The owners have them because they look nice, thats it.. if only they would man up and admit it.
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
