On all on my windows the guides are beginning to scratch the window. Apparently there is a foam guide which wears off over time and then begins scratching the window, its either plastic or metal, while the window moves up and down. Apparently this the case on most R32's and on the GTR's when this occurs it scratches the window in two places.
This is supposed to be a fairly common thing on the R32's. Has anyone come across this and know how it can be fixed?
https://www.sau.com.au/forums/topic/71614-scratched-window-r32-worn-guides/
  • Replies 51
Hey Scott,
I've read in the past that the guides can be adjusted in and out. The manual concurs. If there is still a little foam left on the guide, could you adjust it out to relieve pressure? As far as replacing goes, Mr Nissan is prob the only worthwhile plan.
If you suss out a part number, please post it! :( Cause mine are doing the same but now the glass rattles a little and I need some new ones so I can adjust it back, snug against the window.
Mark
mine is same.. light scratches, pretty bad on drivers side. Anybody know how to remove the scratches? How does one polish glass? Heavy duty buffer?
I've looked in there, and I can't see how it would be obviously scratching it. I can kind of see the guides, but don't see how they are putting the marks there. The best solution may be to buy some new foam, and glue it on the points there.
According to FAST there is a part called 'STAB-GLASS' for 2 door cars. I assume this is something like 'stabilsor-glass'. Anyway the PN is:
80324-04U00
but that is superceded by:
80324-04U03, but this has s different decription: BRKT STOPER (Bracket Stopper).
Can't say whether this is the right part. My GTR's drivers side glass also has scratches.
I assume a glazier can do something to fix the glass. There is one quite close to me but I just haven't had time to investigate.
I did a little research and the main methods seem to be a very lightly abrasive polishing (usually for smaller scratches), or some sort of filler that is used to fill the valleys of the scratch (for deeper scratches). The main thing is to get rid of the white colour that glass turns when scratched: at least if its clear the scratch is not so obvious.
LW.
We've used aluminium oxide and a buffing wheel to polish out minor scratches in glass.   It's also what is sometimes used to 'repair' minor scratches in windscreens.   It's a very slow process.
My scratches are probably beyond just buffing. I will try and call the local glazier tomorrow and see what the can do. Will report back with details when I get them.
LW.
I used to work with glass.
If you can grab the scratch with your nail there's no hope in fixing it.
If its simply light surface scratches then it can be buffed out fairly easily, (5-10minutes) with the right polisher.
Basically a big arsed angle grinder looking thing with a huge white polishing wheel on the end. :)
I had never used it but if you weren't carefull to continually move the polishing wheel it would put an indent in to the glass, which looks crappy and suprisingly stands out quite a bit.
I can't remember what it was called but it was a brown powder that was mixed with water and then buffed with a polishing wheel.
On the note of adjusting the windows has any one done it?
My drivers side window appears to be pointing in towards the car a little and has caused the drivers rubber to rip in the corner. :)
It was fine before the car was sprayed. They must have adjusted it incorrectly.
I have had a quick look, adjusting the closed height is easy but the horizontal movement I couldn't work out.
Mine has done the same, only the drivers side. Rubber is ripped and the window is closing way to far in. It needs to be out another half centremeter or so.
There are four nuts and screws, 2 at the top, two at the bottom. Back off the nuts so you can adjust the screws and this moves the regulator holding the glass.
Its pretty precise though, I ****ed it up, need another go :(
  • 1 month later...
Add me to the list, got it on all FOUR windows, white strips about an inch wide of light scratches. I have 4 replacement pieces of glass but haven't put them in until a) I find out how to stop it happening again. B)I get them from my parents in Melb. c) I can be arsed.
I've been told that windscreen companies can clamp some sort of polisher onto the windows.
Also, be really careful if you're replacing the pads. The little plastic clips get fragile with age.
If anyone prices the pads or the clips, let me know. I've got the same problem ;)
There could be a real market for a group buy of pads by the sound of it. At least it will stop the scratches getting worse.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
