I'm running some Bridgestone RE540's on the R32 atm,
Brilliant dry grip - 10+/10
Normal wet weather grip - 7/10
Price 225 x 50 x 16 - $280 (on closeout)
The thing is that they are great on smooth roads, but due the the very stiff sidewalls and ~2 degrees of neg, they tramtrack badly over uneven surfaces and will unsettle the front through uneven roundabouts. I will be going back to a less rigid semi for my next purchase. Probably a Toyo RA1, my fav previous tyre, not quite as much dry grip as the Bridgestones (still far more than a street tyre), but better wet grip and a softer sidewall.
Jamie
Hankook Ventus K104
235/40/17
255/40/17
$860 fitted to R33 gts-t rb30 284 rwkw 947nm (bloody high-flow)
Don't really like them.
Straight line traction not too good, I know, (too much torque)
1st and 2nd forget it, 3rd so-so
Huge difference when hot or cold.
Feel stable at high speeds, good under brakes.
Hang on ok around corners after 4 laps at Oran Park but too much side wall flex.
Feel a little squirmy when hot.
6/10
  • 1 month later...
Nankang NS2 235/45 17's
Dry performance 6/10
Wet performance 3/10
In the dry once they are warm they were pretty good. though after 3-4 laps you could feel the sidewalls etc moving around. i was pretty happy
for them in the dry for what they are.
In the wet is a different story. No grip what so ever, the smallest bit of throttle would spin the rears and corner speeds would see the rear
the squirm then the front and end up in four wheel sliding, which was a quite unpredictable.
Federal 595RS 235/45 17's
Dry performance 8/10
Wet performance 8/10
While i was impressed with the dry performance of the ns2's these are in the different league. Worth 1-2 seconds on the track easy. corner entry
and mid corner grip is fantastic.
Performance in the wet is unbelievable, having grip turning in and around the corner is amazing. around longer radius corners i could feel the sideways moving around with a hot pres around 38-40. but this was at least quite predictable.
have done 2 track days now, one in the wet and done about 800km on them, only signs of wear are the sidewall fingers are all long gone.
Unitrac focus2000 on stock 33 gtst rims watever size that is
Dry performance 5/10
Wet performance 0/10.. corners I previously took in the wet at 55-60k an hr in my fwd corolla on $60 mystery tyres cant even be taken at 35k an hour.. if I drive through a puddle at 60k an hour in a straightline I aquaplane while other cars pass me with ease at 70k an hour.
Value?/10 these came new with the car when I bought it so im guessing they were the cheapest tyres around, shows you get what you pay for I guess
Sumitomo HTR ZIII
235/40/18
$285 a corner fitted and balanced
Dry 8/10
Wet 8/10
Very stiff side wall, excellent tread design. Handled really well in the last couple of down poors in Adelaide. More grip when hot, but still good and predictable when cold. No where near as much shoulder wear as previous tyres.
KU36
225/55/16
$161 from option1
Dry Performance 8/10
Wet Performance 8/10
Great Tyre for the price, good comprimise between a track and road tyre and handles the wet well.
Still waiting for the right tyre sizes to be available such as 245/40/18 or 265/35/18 locally in Malaysia. Heard many good reviews in many forums. Still miss my Falken Rt615, anyone tested both to advice which is better?
anyone had any experience with......
YOKOHAMA A032R
semi slicks?
Are these similar the...say falken 615's? etc? or a "true" semi slick?
Yeah I had to use them for years because they were our control tyres. They are proper semi slicks but rubbish for the price.
1-3 seconds slower than DZ03 or re55s
no they are too hard if anything, not too soft.
they will be fine if you are happy to go 2 sec slower :P
Just grab some re55s or dz03g to get best performance. Or maybe even yoko a050r.
i need to get new tyres asap, ive looked through this thread but everyone says diffrent things,
what are good tyres for a non turbo r33 gts4?
im thinking maey Federal 595 Rs-R
Edited by sydking
Sumitomo HTR ZIII
235/40/18
Dry 8/10
Wet 8/10
Definitely a very reasonably priced Assymetrical design out there. I was quite impressed with them also.
TOYO R1R
Dry Performance 9.5/10
price for 235/45 R17
is $305 each, which isnt cheap but they do hold on really well and dont make any noise around a corner.
they give you so much more confidence when coming into a corner.
IMO the tyre is the best one you can get for street,
they're a little bit soft, and probably wont last the longest. but even normal city driving you can feel the heat in the rubber when you stop and feel the tyre.
final opinion:
they're not cheap, but well worth the cash if you're after a very high performing tyre.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
