I'm running some Bridgestone RE540's on the R32 atm,
Brilliant dry grip - 10+/10
Normal wet weather grip - 7/10
Price 225 x 50 x 16 - $280 (on closeout)
The thing is that they are great on smooth roads, but due the the very stiff sidewalls and ~2 degrees of neg, they tramtrack badly over uneven surfaces and will unsettle the front through uneven roundabouts. I will be going back to a less rigid semi for my next purchase. Probably a Toyo RA1, my fav previous tyre, not quite as much dry grip as the Bridgestones (still far more than a street tyre), but better wet grip and a softer sidewall.
Jamie
Hankook Ventus K104
235/40/17
255/40/17
$860 fitted to R33 gts-t rb30 284 rwkw 947nm (bloody high-flow)
Don't really like them.
Straight line traction not too good, I know, (too much torque)
1st and 2nd forget it, 3rd so-so
Huge difference when hot or cold.
Feel stable at high speeds, good under brakes.
Hang on ok around corners after 4 laps at Oran Park but too much side wall flex.
Feel a little squirmy when hot.
6/10
  • 1 month later...
Nankang NS2 235/45 17's
Dry performance 6/10
Wet performance 3/10
In the dry once they are warm they were pretty good. though after 3-4 laps you could feel the sidewalls etc moving around. i was pretty happy
for them in the dry for what they are.
In the wet is a different story. No grip what so ever, the smallest bit of throttle would spin the rears and corner speeds would see the rear
the squirm then the front and end up in four wheel sliding, which was a quite unpredictable.
Federal 595RS 235/45 17's
Dry performance 8/10
Wet performance 8/10
While i was impressed with the dry performance of the ns2's these are in the different league. Worth 1-2 seconds on the track easy. corner entry
and mid corner grip is fantastic.
Performance in the wet is unbelievable, having grip turning in and around the corner is amazing. around longer radius corners i could feel the sideways moving around with a hot pres around 38-40. but this was at least quite predictable.
have done 2 track days now, one in the wet and done about 800km on them, only signs of wear are the sidewall fingers are all long gone.
Unitrac focus2000 on stock 33 gtst rims watever size that is
Dry performance 5/10
Wet performance 0/10.. corners I previously took in the wet at 55-60k an hr in my fwd corolla on $60 mystery tyres cant even be taken at 35k an hour.. if I drive through a puddle at 60k an hour in a straightline I aquaplane while other cars pass me with ease at 70k an hour.
Value?/10 these came new with the car when I bought it so im guessing they were the cheapest tyres around, shows you get what you pay for I guess
Sumitomo HTR ZIII
235/40/18
$285 a corner fitted and balanced
Dry 8/10
Wet 8/10
Very stiff side wall, excellent tread design. Handled really well in the last couple of down poors in Adelaide. More grip when hot, but still good and predictable when cold. No where near as much shoulder wear as previous tyres.
KU36
225/55/16
$161 from option1
Dry Performance 8/10
Wet Performance 8/10
Great Tyre for the price, good comprimise between a track and road tyre and handles the wet well.
Still waiting for the right tyre sizes to be available such as 245/40/18 or 265/35/18 locally in Malaysia. Heard many good reviews in many forums. Still miss my Falken Rt615, anyone tested both to advice which is better?
anyone had any experience with......
YOKOHAMA A032R
semi slicks?
Are these similar the...say falken 615's? etc? or a "true" semi slick?
Yeah I had to use them for years because they were our control tyres. They are proper semi slicks but rubbish for the price.
1-3 seconds slower than DZ03 or re55s
no they are too hard if anything, not too soft.
they will be fine if you are happy to go 2 sec slower :P
Just grab some re55s or dz03g to get best performance. Or maybe even yoko a050r.
i need to get new tyres asap, ive looked through this thread but everyone says diffrent things,
what are good tyres for a non turbo r33 gts4?
im thinking maey Federal 595 Rs-R
Edited by sydking
Sumitomo HTR ZIII
235/40/18
Dry 8/10
Wet 8/10
Definitely a very reasonably priced Assymetrical design out there. I was quite impressed with them also.
TOYO R1R
Dry Performance 9.5/10
price for 235/45 R17
is $305 each, which isnt cheap but they do hold on really well and dont make any noise around a corner.
they give you so much more confidence when coming into a corner.
IMO the tyre is the best one you can get for street,
they're a little bit soft, and probably wont last the longest. but even normal city driving you can feel the heat in the rubber when you stop and feel the tyre.
final opinion:
they're not cheap, but well worth the cash if you're after a very high performing tyre.
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
