I found a good cheap boost controller for $22!!!
If you're using resistance mode on the multimeter of course plugging it in with a live battery won't yield a useful reading. Either disconnect the 12V while you do resistance testing or look up what the voltage should be for your current level and chase it back to the gauge cluster to isolate where the failure happens. -
Thanks, I checked from the back of the cluster and no reading there. I undid the connector and plugged in the wires directly to start from where I'm getting a reading: https://imgur.com/a/W8JI6Yr Weirdly enough when I tried to get a reading from the crimps that connect to the fuel pump assembly, I got nothing. Not sure what's my next step as I have admittedly limited knowledge with electricity.
By Neostead2000 · Posted
Agreed with the rest. Also at least based on my own research, there are no readily available stock or close-to-stock RB20Neo maps that you could download and use as a base were you to buy a complete standalone ECU, and the regular 20DET maps don't really work well so you'd need to take it to a tuner if you have no experience. I installed an AEM V2 on my 20Neo+T and had lots of headaches until I got it to run and idle properly but I've yet to remap it fully. You have to start building up your timing and fuel maps entirely from the ground up; even the ones for a 25 didn't work at all.
