can i have my name changed to Luke?
the member with the same username...
http://www.skylinesaustralia.com/forums/in...?showuser=14386
as you see, he has one post and hasnt been active since march 2005
possible?
hey admins, can i please change my username from 'jaimzr33' to 'into oblivion'. cheers
Could I please change my name to J_Red33?
could you change my user name to sloutch please?
Could i please get my username changed to "JET-25L" please....
All done :D
possible?
Not really mate, inactive or not, it's still someone else's account. All I can suggest is to PM the account or send an email to them through their profile, and ask them nicely if they'll change their name or have their account deleted. With any luck they still monitor the registered address :D
Hi Admins
Can i change my nick from gwaping2k to [GTL05T] ?
Thanks in advance. :P
You may... except that IPB won't let us use the [ and ] chars in your display name. Which is annoying because it let me change your login name before it told me that :)
If this is a problem, please let us know an alternative name.
can i have my username changed to (OO\ Black33 /OO)
Thanks in advance
Brad
Normally I'd say yes, given that your name is pretty similar to others already in use on the forums, and doesn't appear to include any 'illegal' characters. That said, IPB bombed out when I tried to change your display name, so I had to change it back. Invision must have changed something there during one of the software upgrades, so unfortunately there's not a lot I can do without pulling a swifty in the back end :D And before you ask... no :P
If you have any other options, post em up and we'll see if we have more luck the second time around!
Not really mate, inactive or not, it's still someone else's account. All I can suggest is to PM the account or send an email to them through their profile, and ask them nicely if they'll change their name or have their account deleted. With any luck they still monitor the registered address :rolleyes:
allright, ill give that a go
thanks for that mate :)
Edited by Luke from boost
(OO\Black 33/OO) (oo\ Black 33 /oo) (oo\Black 33/oo)
Would it accept one of these?
Nope sorry, I suspect it's something to do with the slashes?
can you change my login from YEHBOI to BANGN
Done!
Can i get mine changed from r32 gts-turbo
to
r32 gt-r or r32gt-r
ty in advance
Both of your options are already taken, sorry ;)
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
